HDD lights constantly flashing - no acces to NAS
On the TS-431 everything seems to work fine until all the harddrive LEDs start flashing constantly and then I have no acces to the NAS anymore. No Login, browser fails. Shown on Router though that it is there.
I can manually shut it off via power button and back on, then I run 'check file system' and all is well for a while, from a few hours to days or weeks.
In the System Logs there is nothing unusual.
Model: TS-431
Firmware : 4.2.2 Build 20161102
Number of HDDs: 4
HDD model: WDC WD5000LPVX-00V0TT0 (SATA)
HDD capacity: 465.76 GB
RAID configuration: Raid 5
Windows 10 or Android App is used to acces NAS
Model: TS-431
Number of HDDs: 4
Re: HDD lights contantly flashing - no acces to NAS
when the NAS is unresponsive .. does SSH access still work ?
so you have 4x2.5" WD blue drives (strange choice for drives) but what is your RAID config ? .. what is group 2 ?
I do not know if SSH works, as I don't use it due to lack of knowledge on how to
it's a raid 5 . all drives are in group 2
what do you mean by group 2 ?
where does it say group 2 ?
see attachement
I guess you had two RAID groups and deleted Nr.1 at one point ?
anyways...
for windows you can use putty for SSH access, default username is admin (and password is the password you have given the user admin)
anyways...
ok.
I will try that as soon as it starts blinking again,
I had to manually shut off and turn it back on again to get the information that was needed to post here.
Re: HDD lights constantly flashing - no acces to NAS
this time only stayed up for a couple of hours..
seems not accessable by putty
in putty, I put under Hostname
admin@xxx.xxx.xxx.xx (my qnap ip address)
comes up with black screen and no text, green cursor
the ip is your private one? (censoring that is unnecessary..because its not routable and most if all not unique)
like 192.168.1.50
like 192.168.1.50
yup, the static ip I gave the NAS on my router
i think best is to open a ticket with qnap
ok. thank you
what would the issue category be?
I personally never opened one .. just chose one that fits best ..
Hi
I have the same prob, have you just solve it ?
Thx
Thx
First post..
I just got a TS-431 myself a week ago and am having TERRIBLE connection problems. Heck, I even ditched my Apple Airport Extreme and got a brand new Linksys WRT3200ACM because I thought maybe Apple's router wasn't playing nice with the Qnap.
No dice.
It'll connect fine after I wipe/restore for a few hours and then suddenly just disappear. I haven't been able to keep the NAS online for more than 24 hours this week before it just goes bye-bye, SSH not working either. I use OSX so I've been SSH'ing through Terminal.
I have two, 3TB WD reds in RAID-1. I'm not at home right now so I can't see my configuration, and I can't log into the NAS at all either remotely.
BTW, does anyone know how to turn the darn thing off/on? If I push the power button nothing happens. If I do the 3-second thing it resets some settings, and the 10 second wipes it. I just want it to shut down and restart. Also, I do not see a "reset" button anywhere on the thing. Only a power and copy button on the front.
The thing was a birthday gift and I hate to have to ask that it be returned.
I'll try and get screen caps and data tonight when I get home.
No dice.
