HGST 4tb 128 cache and Qnap 873
Has anyone used these disk with the 873. It is not on the compatible list and when I emailed qnap to ask them they said it has not been tested with them yet. I find many disks for sale with the system that are not on the compatible list from places such as SimplyNAs so not sure what to get. They said that simplynas does work closely with them.
Re: HGST 4tb 128 cache and Qnap 873
If SimplyNAS or anyone else sells a combination of products without it being approved by the respective manufacturer, then I guess you need to trust the reseller to have done the necessary compatibility testing. If you don't trust them, then buy a NAS without disks or buy somewhere else.bapw@comcast.net wrote:I find many disks for sale with the system that are not on the compatible list from places such as SimplyNAs so not sure what to get.
