Can anyone tell me how to install CVE-2017-7494 patch??
Download patch from the QNAP site. Unzip it so you have a .qfix file. From your NAS, proceed as if you were doing a firmware update.
From the Firmware Update page, browse to where you unzipped the .gfix file and install just as you would do for a 'conventional' firmware update.
TVS-471
- Moogle Stiltzkin
Re: Can anyone tell me how to install CVE-2017-7494 patch??
in addition there are methods to verify if the patch is effective. in another user's thread i posted the link to that. you can use the search find it.
NAS
Network
Resources
Network
Resources
- Johnno72
- Easy as a breeze
Moogle, can you verify this patch working ok so far as you know
OS: Win10 Professional v2004 OS Build 19041.388 x64
NAS: QNAP TS-EC2480U-RP 16G 24 Bay - Firmware: v4.4.3.1421 build 20200907. Updated from v4.4.3.1400 Build 20200817 Official
StoragePool / DataVol: Storage Pool 1 / DataVol1: Single 29.04TB - Thick Volume: 29TB
HDD's: Western Digital - Model: WDC WD4001FFSX-68JUN0 Red Pro NAS 3.5"
HDD Size: 4TB - HDD Firmware all HDD's: 81.00A81
RAID Configuration: RAID6 x 10, HotSpare x 1, ColdSpare x 1 - Network: 1GbE
UPS: CyberPower PR3000ELCDRT2U Professional Rackmount LCD 3000VA, 2250W 2U Line Interactive UPS
QNAP Hardware details required: viewtopic.php?f=5&t=68954
Remote Administration of: TVS-863+ 16G on UPS Cyberpower OLS1500E+RMcard205
- Moogle Stiltzkin
i read somebody verified it worked after they restarted once they patched it. i'm no expert but i'll take that as it's fixed :]Johnno72 wrote:Moogle, can you verify this patch working ok so far as you know
i posted quite a bit on this topic here
viewtopic.php?f=11&t=133018#p617765
NAS
Network
Resources
Network
Resources
- Johnno72
- Easy as a breeze
I just jumped in and performed the manual update patch, all went ok, the reboot actually took at 1 minute 47 seconds longer... simply could not access the NAS even though it showed as connected to the network. All appears OK so far.
- Easy as a breeze
I'm currently on 4.3.3.0154 Build 20170413 and have applied this patch.
I'll probably get round to upgrading the firmware this weekend to 4.3.3.0188 build 20170516
Will I need to re-apply this fix after doing the minor firmware update taking into account the fix was released after the current latest stable firmware.
Unless I'm being blind, I can't find the setting to change what kind of QNAP I have on my profile. I now own a TS-253A
- schumaku
Yes, you have to re-apply the fix. There are no firmware images available yet inheriting it.ensignvorik wrote:Will I need to re-apply this fix after doing the minor firmware update taking into account the fix was released after the current latest stable firmware.
