Anybody successfully uploaded firmware to a TS-569 as per the instructions in https://wiki.qnap.com/wiki/Firmware_Recovery
When I boot from a DSL USB stick I get a message "Autodetection seems to hang - Please check your computer BIOS"
a few more commands are run but it never brings up the DSL screen
I've tried disabling UEFI and high res graphics
TS 569 Pro Firnware reload
Model name TS-569 Pro
Firmware version 4.3.4.1463 Build 20201006
HBS3 V 3.0.200113
HBS3 V 3.0.200113
Re: TS 569 Pro Firnware reload
Managed to boot using Puppy linux,then I used DD command to copy over the image file, now I get a QNAP splash screen and welcome to use the Qnap products message but it
just to a linux login prompt.
Any ideas ?
Any ideas ?
HBS3 V 3.0.200113
HBS3 V 3.0.200113
I don't think much more than the linux prompt should appear .. QNAP uses a web frontend for configuration and operation , not the video output
Only after any app that uses the video output (e.g. HD station) was installed, will there be any output on the HDMI
Sorry was having a bit of a brain fade,so preoccupied with Linux
Anyway Qfinder now seeing unit and have updated it to latest firmware
HBS3 V 3.0.200113
HBS3 V 3.0.200113
