ts-228a no power
ts-228a no power
Hy,
within 3 months my ts-228a is broken. both have the same error. I can not turn it on. No reaction when I use the power switch. The power supply is OK.
Hass anyone the same issue and how can i copy the contents of HDDs whithout a qnap. I want to switch to another NAS.
Two broken systems is to dangerous for me.
thank you for your help
Re: ts-228a no power
sound like this
viewtopic.php?f=45&t=143673&p=686101
reading the contents without a QNAP will be a hard task .. you should have done external backups
yes, this is the same issue.
really seems to be very unreliable hardware.
Unfortunately I only have one backup from the first qnap. Data is current but has a different structure.
maybe I will find a Live-Cd from qnap to read the HDD's
As far as I know, uses qnap the ext4 format
modern QAP use LVM on top of the mdadm (if there is a raid) ..that makes it MUCH harder to get to your data
Thank you for your help.
yes, does not look good.
So I'll reclaim the TS-288 (is the easiest way) and buy me a synology as soon as possible. the synology never made any problems.
Yesterday, my QNAP TS-228A also stopped turning on. Worked only one month.
Maybe this is a problem in the firmware? The power supply is working. The fan tries to spin and immediately stops.
seems to be a serious hardware error
yesterday they replaced my NAS with a new one. I had to do this, because this was the only way to get my data back.
I am not happy with the 228A. Next time it stops working, i get the money back and buy a synology.
A daily backup is now on my ToDo-List
The problem is that my supplier does not currently have a TS-228a. The nearest service center is 9000 km away. I will give us a supplier, let him solve this problem.
This is bad. Hope your supplier can manage it soon.
I have the same problem with the TS-228A, No power and the power supply is still working fine. After working for 1,4 years it suddenly stops, the replacement was also broken in less then 3 weeks. Whats going on?
How many other people have this problem with this type?
Another one... Yesterday when I arrived home, my unit was totally dead
It's my second TS-228A unit that fails in 3 months, very annoying. Seeing that first message of this thread is 1 year old, I wonder why QNAP does not fix what seems to be a design issue.
I've faced the same issue. My TS-228A died suddenly couple of days ago
My TS-228A just died as well. 16 months old. Off to buy a new unit, transfer the disks over and hope for the best.
