How long is your Boot time?
spikemixture
Been there, done that
Post by spikemixture »
How long does it take your NAS to boot?
I have a TVS-1282 32gb with 8x 8TB drives 4x SSD and 4x M,2 SSD
A few VM's (1 running 24/7), Plex plus several other apps.
It take around 10 minutes to be seen by Qfinder then another 5-10 mins to load the programs.
Reboot add another 5 minutes at least while apps close..
Just moved my power source so shutdown NAS
On booting was stuck on Bios Memory checking for 20+ mins and had to physically shutdown and start again
So that was a 45 minute boot !
Qnap TS-1277 1700 (48gb RAM) 8x10TB WD White,- Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 6x8TB WD White - JBOD, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - DOA
Drobo 5n - 5x4TB Seagate, - Drobo Raid = 15TB
ProBox 8 Bay USB3 - 49TB mixed drives - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it! :roll:
manfredell
Know my way around
Re: How long is your Boot time?
Post by manfredell »
TVS1282T3 with TX800P:
the stuck on Bios thing has hit me in the past a few times, if it doesn't pass this test for more than 30 secs it's hard reboot time!
Normal boot (until the blue light stops blinking) takes 5-10mins I guess, never timed it but it is rather long.
TVS-h1288X, TBS-464, TVS-1282T3, TVS-872XT
spikemixture
How long is your Boot time? - DON't OPEN if you can't answer
Why have 80 people looked at this post and 1 replied?
How long does it take to reply with a number - 2 minutes, 5 minutes etc etc.
Less than it takes to open and read this post I bet..
GTX 1050 TI
albumman
Easy as a breeze
Re: How long is your Boot time? - DON't OPEN if you can't answer
Post by albumman »
spikemixture wrote: Sat Dec 08, 2018 11:21 am Why have 80 people looked at this post and 1 replied?
If I had the same model as yours, I would reply.
TS-212P QTS: 4.3.3.1864 build 20211212
2 x Seagate ST3000VN000 (RAID 1)
spikemixture
albumman wrote: Sat Dec 08, 2018 9:31 pm
Valid point but how will anyone know if it is the model and apps or the OS taking so long if no one answers!
GTX 1050 TI
orinoko
Post by orinoko »
Mine takes a while, waiting for the 'bleep' around 6 minutes - got no vms but have container station and the usual stuff, kodi etc
NAS:
TS-451+ RAID 5
QTS 5.1.0.2399 RC
8GB 2x4GB
mdhwoods
Know my way around
Post by mdhwoods »
lately mine hangs on reboot and requires a hard reboot. Started a few firmwares ago. usually only when its been running for some time. i have a tvs-682 and it takes a while to reboot even when it doesnt hang.
Trexx
Ask me anything
Post by Trexx »
And have you guys opened help desk tickets to see if it would a a bios issue needing fixed, qts issue, etc.
Posting times, me too’s without opening help desk tickets is kinda pointless since QNAP doesn’t actively monitor the forums.
Paul
UPS: CP AVR1350
spikemixture
I am asking because compared to a Synology NAS of similar size it takes 3-4 x as long.
If 10+ minutes is the norm then not much use opening a ticket .
Going by the very few answers it appears to be a qnap thing but 3 outta 450+ views is not much of a survey!
GTX 1050 TI
panto
Know my way around
Post by panto »
They are slow to boot and it seems to get worse as they get newer and newer firmware. As a comparison my old TS-439 shuts down and boots lightning fast running Debian when compared to my TVS-882 running QTS.
TS-439 Pro running Debian Stretch, TVS-882 running QTS.
grouillier
Post by grouillier »
I'm interested in this, so I'll post my experience. I just purchased a TS-230 with a single 3 TB Western Digital Red Plus drive. I noticed just now that the device takes a long time to become available after startup. I hear the beep pretty quickly - I'd guess at about 1 minute. But the box is not pingable on the network for at least 5 minutes. So, I took a look at QuLog Center, and here's what I see:
Information	2021-04-27	21:42:59	admin	127.0.0.1	Power	NAS Power Status	[Power] System started.
Information	2021-04-27	21:43:00	admin	127.0.0.1	Network & Virtual Switch	---	[Network & Virtual Switch] Initialized Network & Virtual Switch.
Information	2021-04-27	21:43:00	admin	127.0.0.1	Network & Virtual Switch	Infrastructure	[Network & Virtual Switch] Set "Adapter 1" as the system default gateway.
Information	2021-04-27	21:43:01	admin	127.0.0.1	Network & Virtual Switch	Infrastructure	[Network & Virtual Switch] Set "Adapter 1" as system default gateway. "Adapter 1" connected to the internet after checking NCSI.
Information	2021-04-27	21:45:37	admin	127.0.0.1	Malware Remover	General	[Malware Remover] Started scanning.
Information	2021-04-27	21:47:19	admin	127.0.0.1	Malware Remover	General	[Malware Remover] Scan completed.
The system was definitely not reachable 2 seconds after startup, despite the log claiming that the adapter was connected at that time. If I had to guess, I'd say I couldn't connect from my PC (on same physical switch) until after the Malware Remover was done and the disk quieted down. That's a little annoying actually that it takes this long. Perhaps I'll adjust the Malware Remover to only run once a week. I only connect to this QNAP for backups, inside my house - no connectivity from outside - and I run anti-virus on my Windows systems (and I'm old, so low risk profile.)
I previously had an old PC running Linux as homegrown NAS. I got spoiled by that being available probably 15 seconds after power on. I'd be interested to see any additional reports of availability delay after power on.
TS-230, TS-253A, both with latest stable QTS
Guapo81
Know my way around
Post by Guapo81 »
spikemixture wrote: Mon Dec 17, 2018 3:17 pm I am asking because compared to a Synology NAS of similar size it takes 3-4 x as long.
I would say 10+ minutes is definitely the norm.
I have my main NAS (TS-h886) set up like yours I guess, running PLEX and several other apps. From triggering a reboot, stopping all apps, restart to finished reboot, so all apps started again takes around 22 minutes in my case..
My TVS-682 is quite a bit quicker, but that has mainly to do with the fact that pretty much the only app it's running is HBS3, but apart from that 8 - 10 min does not sound strange to me also.
mdhwoods wrote: Fri Dec 14, 2018 10:02 pm lately mine hangs on reboot and requires a hard reboot. Started a few firmwares ago. usually only when its been running for some time. i have a tvs-682 and it takes a while to reboot even when it doesnt hang.
My TVS-682 had the same problem quite some time ago, strangly enough it did not happen at every reboot.
Nowadays I believe I don't have this problem anymore, but then again, my TVS-682 is actually not running any apps anymore, so this could be what changed it..
QNAP TS-h886-64G 2x Samsung 970PRO NVMe SSD (RAID1, System), 2x Samsung 860 PRO SSD (RAID1, VM) 4x Seagate EXOS X16 16TB (RAID5, Data) - FW: QuTS-hero
QNAP TVS-682-i3-32G 4x HGST HUH728060ALN600 (RAID5, Backup) - FW: QTS
QNAP TVS-463 4x Seagate ST2000VN000 (RAID5, Surveillance, Backup) - FW: QTS
Former units: TS-469Pro, TS-459ProII, TS-269Pro, Qgenie
AlbertFishtucker
First post
Post by AlbertFishtucker »
5m20s - TS-230, got a few apps Plex, and the photo management ones, etc
Seems like an age, sux to have it over 10m :(
It wasn't until 5.20 that I got the final beep, then I could load the page and log in
spikemixture
Thanks to the guys that answered.
It does appear to be the norm for Qnap boxes to take a long time.
Most well over 5 minutes and upto 22 minutes from a post here.
Currently my 1277 takes 15 minutes from clicking reboot to apps being usuable!
GTX 1050 TI
dawsonkm
Getting the hang of things
Post by dawsonkm »
My boxes take 5-7 mins. I'm running very few apps on them
TS-431X2 QTS 4.4.3.1439 - Static Vol 4 x 8TB Hdd Raid 5 Using 10GBE
TS-431P2 QTS 4.4.3.1439 - Static Vol 4 x 8TB Hdd Raid 5
TVS-1282T QTS 4.5.4.2012- Static Vol 8 x 16TB Hdd Raid 6, Static Vol 4 X 8TB SSD Raid 5 Using 10GBE
