TVS-951x Memory Upgrade
Hello Gurus,
I am new to this forum. I recently bought a new TVS-951x NAS with 2 GB memory. If I want to upgrade RAM on this NAS, what are my options? Do I have to buy QNAP brand memory or buying other brands will be okay too? Any specification for the RAM.
I am sure this question was asked here before but I couldn't find the relevant information. My apologies and thank you for your help.
Thanks,
Vipul
Thanks,
Vipul
Re: TVS-951x Memory Upgrade
In the earlier topic (viewtopic.php?f=182&t=145514&p=697485), there were some issues with RAM used where it was not detecting the full memory and only detecting the memory from 1 slot or half the total RAM size.
Any idea what would have caused that? I am planning to upgrade my NAS to 32GB (2*16GB) memory. If I am not wrong, 32 (2*16GB) memory is the max this NAS can support. Please help so I can upgrade.
i have both ranks filled..even with different sizes..so that shouldn't be an issue
I just didn't see a need for 32GB of ram ... unit performance and my usage case do not justify it
Thank you. So, any DDR4-2400 will be compatible with this NAS, or any other specification like CL-16 or CL-17? Thank you for your help.
try it out and report..buy it from somwhere with a no questions asked return policy..in case it does not work
No.
The problem is that only the expensive Qnap RAM is supported by Qnap. This means:
- Qnap may not offer support on a RAM expanded NAS, so keep the original RAM to be able to restore it to a supported configuration later when you need support from Qnap.
- Qnap does not list RAM specifications or have a comaptible RAM list so users are on their own finding out what works and what doesn't. Usually hints about RAM expansion can be found here in the forum but there are no guarantees.
Cheers! You found my previous thread!
My 2x16gb Corsair Vengeance 2400Hz would not recognize installed into neither my 951x, nor my DS1819+. The ram I was successful with was G.Skill RipJaws 2400 19200:
Best of luck. Absolutely keep the original ram for any RMA warranty issues, as earlier stated.
Is there a fix for the DEADBOLT Hack???
Can anyone tell me if both slots must be used? Can I install one 8GB or 16GB module and not use the other slot for now?
they come from factory with one module .. so yeah .. one module can be used
I bought an 8GB module and used the 2Gb it came with (10GB) works fine
- itsmarcos
- Easy as a breeze
Just for anyone looking to buy RAM. I found a bargain of a set of Crucial 32GB Kit (2 x 16GB) DDR4-2400 SODIMM - CT2K16G4SFD824A and it works on the TVS-951x. https://www.crucial.com/usa/en/ct2k16g4sfd824a
Primary
QNAP TVS-951N [latest QTS 5.0.x]
- disk 1: WDC Red WD80EFZX
- disk 2: WDC Red WD80EFZX
- disk 6: Samsung SSD Evo 500GB, SSD Cache
- disk 7:Samsung SSD Evo 500GB, HybridMount Cache
- External disk: WDC Red WD60EFRX
Dead one
QNAP TS-253B [4.4.x] - now dead
Remote backup
QNAP TS-219 P+ [latest 4.3.x]
- disk 1: HGST Deskstar 7K3000 HDS723030ALA640 3TB
- disk 2: WDC Red WD40EFRX
Do you know if this particular RAM is compatible with TVS-951x NAS?itsmarcos wrote: ↑Thu Aug 01, 2019 9:52 pm Just for anyone looking to buy RAM. I found a bargain of a set of Crucial 32GB Kit (2 x 16GB) DDR4-2400 SODIMM - CT2K16G4SFD824A and it works on the TVS-951x. https://www.crucial.com/usa/en/ct2k16g4sfd824a
I don't get that questionvipulgarg wrote: ↑Thu Aug 29, 2019 1:10 amDo you know if this particular RAM is compatible with TVS-951x NAS?itsmarcos wrote: ↑Thu Aug 01, 2019 9:52 pm Just for anyone looking to buy RAM. I found a bargain of a set of Crucial 32GB Kit (2 x 16GB) DDR4-2400 SODIMM - CT2K16G4SFD824A and it works on the TVS-951x. https://www.crucial.com/usa/en/ct2k16g4sfd824a
I wanted to know if are using this memory module (Crucial 32GB Kit (16GBx2) DDR4 2400 MT/s (PC4-19200) DR x8 SODIMM 260-Pin Memory - CT2K16G4SFD824A) with TVS-951x. I just placed the order for this memory. Hopefully it will work with my NAS.dolbyman wrote: ↑Thu Aug 29, 2019 1:15 amI don't get that questionvipulgarg wrote: ↑Thu Aug 29, 2019 1:10 amDo you know if this particular RAM is compatible with TVS-951x NAS?itsmarcos wrote: ↑Thu Aug 01, 2019 9:52 pm Just for anyone looking to buy RAM. I found a bargain of a set of Crucial 32GB Kit (2 x 16GB) DDR4-2400 SODIMM - CT2K16G4SFD824A and it works on the TVS-951x. https://www.crucial.com/usa/en/ct2k16g4sfd824a
if itsmarcos says it work (and according to the sig that is one of the NAS units he owns) .. it's kind of a given that they work
