How do you use a Graphics Card?
- spikemixture
- Been there, done that
Do you use your added graphics card for Virtualization and then what?
Or video transcoding, coding/remuxing/converting, HD Station?
I have just put an AMD graphics card in my TVS-1282.
I do some re-coding/converting of media in a win10 VM and was hoping the card would take some of the load off the CPU.
I have read the instructions and Qnap sees the Card and Virtualization Station sees it.
But Once I add the card via the PCIe option I get a VNC Authentication box pop up can go no futher as I have not set VNC password.
The instructions show the setting up of VNC screen as a process once in win10 after being instructed to add the card!
Have reversed the process and adding VNC and creating a password - then the card but after signing in I get black screen only.
Qnap TS-1277 1700 (48gb RAM) 8x10TB WD White,- Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 6x8TB WD White - JBOD, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - DOA
Drobo 5n - 5x4TB Seagate, - Drobo Raid = 15TB
ProBox 8 Bay USB3 - 49TB mixed drives - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it!
GTX 1050 TI
- spikemixture
Re: How do you use a Graphics Card?
334 views and apparently not one has a graphics card!
Possible but unlikely.
I wonder the record for views with no answers?
GTX 1050 TI
GTX 1050 TI
I’d like to know about this as well. It doesn’t seem like QNAP wants anyone to know how to use non QNAP hardware. I’m struggling with adding wireless and struggling with what video card I can insert or even if my unit is compatible. I have a QNAP 1635 which is NOT x86 based.
I’m following this and I hope someone tells you what you need to know
highly doubt you can use a graphics card on a little cell phone processor...no driver compatibilty
- spikemixture
My NAS has an Intel I7
GTX 1050 TI
GTX 1050 TI
I should have quoted..my comment was in regards to the TS-1635 just before my post
- Trexx
Plug in card to NAS
Hookup monitor via HDMI to card
Hookup keyboard/mouse to NAS via USB
Assign card to VM
Assign usb keyboard/mouse to VM
Install windows 10 (using keyboard/monitor)
Install AMD Drivers into Windows
Done
Use RDP client to remotely connect if needed once done.
Assign card to VM
Done
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- Moogle Stiltzkin
possible usesspikemixture wrote: ↑Mon Jul 29, 2019 1:55 pm Do you use your added graphics card for Virtualization and then what?
- VM (thx to VM passthrough making this possible in the recent years. I forget starting from which QTS exactly). Then you can use the QNAP as if it were a desktop pc essentially.
- transcoding graphics card hw acceleration (for native videostation app yes it worked. but it was only recently with QTS 4.4.1 where they updated the nvidia drivers did it become supported for Plex and emby. I don't have premium accounts for either so i could not confirm this myself. but according to their devs and other users, it works kinda atm)
- Qumagie makes use of graphics for accelerating it's image processing for facial/object tagging.
in the QTS hardware settings there are 3 modes for graphics card
- Virtualstation (VM)
- QTS (this is for qumagie, videostation, plex/emby )
- container station
*notes: whenever changing to a different mode and applying, you are required to restart the NAS for it to become effective with the new setting
NAS
Network
Resources
Network
Resources
- spikemixture
I have only Virtualization as an option.Moogle Stiltzkin wrote: ↑Sat Aug 03, 2019 12:04 pmpossible usesspikemixture wrote: ↑Mon Jul 29, 2019 1:55 pm Do you use your added graphics card for Virtualization and then what?
- container station
I would really like the QTS option
GTX 1050 TI
GTX 1050 TI
- Moogle Stiltzkin
huh? thats weird. there should be 3 modes you can select from. only 1 of them can be active. unfortunately you can't use all 3 same time... must pick one then reboot to apply the new setting.spikemixture wrote: ↑Sat Aug 03, 2019 9:39 pm I have only Virtualization as an option.
what qts version are you using?
NAS
Network
Resources
Network
Resources
- Trexx
AMD cards are not supported for Qts mode to start with and I don’t believe even Nvidia cards are supported in qts mode IF the NAS has embedded GPU which the x82 family does.
Also I believe container station pass through only supports Nvidia cards as well.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- spikemixture
Trexx wrote: ↑Sun Aug 04, 2019 3:43 am AMD cards are not supported for Qts mode to start with and I don’t believe even Nvidia cards are supported in qts mode IF the NAS has embedded GPU which the x82 family does.
Ok I am beginning to understand why this topic has had so few replies.
So no card can do what Qnap suggest here ?
GTX 1050 TI
GTX 1050 TI
- Trexx
NVidia cards work just fine for that on supported model NAS with NO embedded GPU (like my TS-877, TS-1685, etc.).
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- spikemixture
And the TVS-1282?
GTX 1050 TI
GTX 1050 TI
I think all available CPU's for your model have integrated GPU's
