Safety remove hard driver from QNAP NAS Raid 5 Storage Pool
sieupetvn
First post
Post by sieupetvn »
Hi every one,
I have QNAP NAS with storage pool in Raid5 (8 SSDs 2TB)
Now we wanna increase storage pool and remove 2 SSD from Raid group.
I try to looking for some guide but almost are extend and add more disk to storage pool.
Any body might help me pls
P3R
Re: Safety remove hard driver from QNAP NAS Raid 5 Storage Pool
Post by P3R »
The number of disks in a RAID group can never be decreased. The only possible way to do that is to:
  1. Backup all data
  2. Remove the current RAID group (including pool and volumes on it)
  3. Create a new RAID group and storage pool and volume(s)
  4. Restore data from backup onto the new volume
How do you intend to remove disks and at the same time increase the storage pool? Are you going for much larger disks?
