Does anyone have a link or attachment that specifically gives instructions for upgrading my TS569 Pro from 1GB to 3GB of memory. I cannot find a video or good documentation that shows how far to take the box apart for this model to get to the 2 slots. I hate to just go for it if there is an easy way.
Al
TS-569 Pro Memory Upgrade
Re: TS-569 Pro Memory Upgrade
Thanks Dolbyman. I looked all over for this and got lost in all the docs for everything. It looks like it uses a 2GB DDR3 1333MHz PC3-10600 SODIMM RAM 240 pin i believe. Any recommendation on suppliers that work better than others with qnap boxes?
