QNAP backplane replacement with different model
brizio71
Post by brizio71 »
Is it possible use a different backplane on my QNAP ?
I have a QNAP TS-1079 Pro and I would like use TS-653 Pro backplane, do you think can it work ?
Thx
P3R
Re: QNAP backplane replacement with different model
Post by P3R »
Without knowing I'd say that it's extremely unlikely that it would work.
jaunais2
Post by jaunais2 »
Similar question:
Can I use a backplane from NAS TS-653 Pro (QW52 v1.1) on a similar TS-653A (backplane QX66 Rev 2.0 it's defected).
Motherboard in TS-653 Pro and TS-653A like's very similar.
Thx.
khronos
Post by khronos »
jaunais2 wrote: Sun Feb 02, 2020 1:08 pm Similar question:
Thx.
I have the exact same problem! I have a TS-653A with a defected backplate, out of warranty, and the cost for repair is insane!
I also have a TS-669L (The backplate it uses is the one for TS-659 Pro II. It is printed on the backplate.)
Can I use it for my TS-653A?
The problem is that I cannot find a replacement for my QX66 Rev 2.0...
Did you find any solution?
1x TS-653A (with defective QX66 Rev:2.0 backplate. Only first two sata ports working...)
1x TS-509 Pro (I broke it... I need a replacement working mainboard... Can anyone help?)
1x TS-453 Pro
1x TS-669L
1x TS-453A
1x TS-459 Pro+
charlyd
Getting the hang of things
Post by charlyd »
please see my post here in hardware topic about backplanes
please get in touch with me
- Qnap Storage, looking for repairs from all sorts of hardware/backplane problems. [ for reasonable prices ]
( but also Tektronix, Agilent, Keysight and many more.. Scopes, Logic analysers, dmm & more..)
->> Get in touch with me on c.dickens@xs4all.nl ( no diagnose by email )
Professional hardware engineer
charlyd
Post by charlyd »
@khronos i am particulair interested to have a look at your QX66 backplane. i am reverse engineering some other models. and as i am right they all fail a sort of same way.
( lets call it bad development). :-$
bcn_es2
Post by bcn_es2 »
Same problem with a TS-453 Pro, for the moment I can't find (to buy) the same model,
Do you know any new model to buy, where I can plug my 4 HD in RAID-5 keeping the data ??
FSC830
Experience counts
Post by FSC830 »
You can find a compatible model at https://www.qnap.com/en/nas-migration!
Regards
