QNAP 672N CPU Upgrade
lv.onlythebrave
Post by lv.onlythebrave »
Planning to upgrade my NAS system and getting new released 672N, anyone knows is i7 CPU upgrade possible on this one? Also looking at 472xt - if i go with this one, I will lose 2 bays and get thunderbolt
Price point is similar for both.
dolbyman
Re: QNAP 672N CPU Upgrade
Post by dolbyman »
dont think anyone here has this nas yet
but processor updates should work within same tdp specs as the original cpu
https://ark.intel.com/content/www/us/en ... 0-ghz.html
thunderbolt is pretty limited on 4 spinning disks (speedwise)
lv.onlythebrave
I hope the processor is not soldered. Pretty new to qnap, migrating from syno. Also can you suggest which i7 processor would have same tdp specs? thnks
rgarjr
Know my way around
Contact:
Post by rgarjr »
lv.onlythebrave wrote: Tue Oct 22, 2019 1:10 pm I hope the processor is not soldered. Pretty new to qnap, migrating from syno. Also can you suggest which i7 processor would have same tdp specs? thnks
If I had that model, I would probably get the
i7-8700T
i7-8700 has a higher TDP, will definitely run warmer.
[TS-1677x] - Ryzen 2700, 64GB RAM, PSU: Corsair SF600 - [TS-1277] - Ryzen 2700, 64GB RAM - [TS-877] - Ryzen 2700, 64GB RAM - [TS-677] - Ryzen 2700, 64GB RAM, PSU: Corsair SF600 - [TVS-472xt] - i7-8700, 64GB RAM, PSU: Enhance Electronics 600W ENP-7660B - [TVS-871u-rp] - i7-4790K, 32GB RAM
lv.onlythebrave
thanks, ill try to get the 672N and go for this upgrade !. Anything I can do to keep the temp under control, hopefully it should not get too hot.
dolbyman
Post by dolbyman »
lv.onlythebrave wrote: Thu Oct 24, 2019 4:21 am thanks, ill try to get the 672N and go for this upgrade !. Anything I can do to keep the temp under control, hopefully it should not get too hot.
going for low TDP version and not taxing it too much .. you never specified why the default CPU is too weak for you
jeff.r
Post by jeff.r »
I recently acquired the 672N and did 32G memory with the i7-8700T. Works great! Easy upgrade also. Just have your thermal paste ready to go...and it's three screws for the case cover, then four screws for the CPU heat sink. Drops right in...no issues.
QNAP TVS-672XT
- QTS 4.4.3.1439
- i7-8700T (Part No. SR3WX)
- 32GB Mem (Crucial CT2K16G4SFD8266)
- 6x WD Red 6TB RAID6
- 2x 970 EVO Plus 500GB NVMe M.2 RAID1 (Cache)
- APC SMT750C Smart-UPS
pimp-boy
First post
Post by pimp-boy »
Hi Jeff.R
I just purchased the TVS-472XT... Can you let me know the Crucial memory model you used to upgrade your 672?
Thanks!
Bbeal
Post by Bbeal »
jeff.r wrote: Wed Nov 06, 2019 2:13 am I recently acquired the 672N and did 32G memory with the i7-8700T. Works great! Easy upgrade also. Just have your thermal paste ready to go...and it's three screws for the case cover, then four screws for the CPU heat sink. Drops right in...no issues.
Can you confirm or deny that the cpu will not use turbo boost / always stuck at 2.4 under any load? Im thinking of doing the same upgrade.
RichJacot
Post by RichJacot »
Bbeal wrote: Thu Feb 06, 2020 7:24 am
I would also be interested in this upgrade. CPU P/N?
Also, it appears to have been a bit since you did this upgrade. Any issues? How are your temps?
TVS-672N - 32GB - 4.5.1.1594 - Static volume - RAID5 - 6 x 10TB Ironwolf --- Thick Volume RAID1 - 2 x 500GB M.2 SSD - CT500P1SSD8 in a QM2-2P10G1TA
TS-453B - 16GB - 4.5.1.1540 - Static volume - RAID5 - 4 x 4TB WD Red
ntamu
Post by ntamu »
I bought the cpu Intel i7-8700t in ebay, model SR3WX 2.40GHZ to replace the i3 on my TVS-672N and it works great, normal temp ~33ºC all time, and doing Plex hardware transcoding 4k ~39º-40º, so I'm very happy :D , if you need more details or some test just let me know how to execute the test and I will answer you with the results.
regards,
RichJacot
Post by RichJacot »
Thank you!
I just got my 672N last week so I won't immediately be doing this upgrade but it will definitely be on my to-do list.
sunny1283
Post by sunny1283 »
Now the question is where to get 8700t for a good price...
ntamu
Post by ntamu »
sunny1283 wrote: Sun Apr 26, 2020 8:07 pm Now the question is where to get 8700t for a good price...
It seems that the 8700t is sold to OEM pc builders, so it's difficult find in retail computer stores, I bought the cpu in Ebay, the seller said that was extracted from a new pc to replace it with a better one, I paid for it 170€, so you could take that price as reference to buy or bid.
Regards,
sunny1283
Post by sunny1283 »
ntamu wrote: Tue Apr 28, 2020 12:11 am
Regards,
Thanks!
