When connecting my MacBook Pro via Thunderbolt 3 to the QNAP TVS-672XT, my write/read speeds are consistently in the region of 830/1200MB/s (verified using Black Magic Speed Test), but when I use the 10GBase-T interface, write speeds remain consistent with the Thunderbolt 3 interface (830MB/s), but read speed drop way down to just 400-450MB/s.
I tested the 10GBase-T link speed from my MacBook Pro > Akitio Thunderbolt 3 Dock Pro > QNAP LAN 1 using iPerf3, and it reports Bandwidth for both directions at 9.35Gbits/sec, so nothing wrong with that.
Can anyone help or offer a suggestion on what might be going on? I can't understand why the 10GBase-T interface can keep pace with the Thunderbolt 3 interface for write operations, but slows so badly on read (I know 10GBase-T can't match Thunderbolts 1200MB/s read, but I would expect it to be in the region of 900MB/s).
TVS-672XT Slow 10GBase-T Read Speed
QNAP TVS-672XT Upgraded to 16GB RAM connected via Thunderbolt 3 to Late 2018 MacBook Pro
M.2 Bays = 2 x Samsung 1TB EVO 970 NVMe (RAID 0 for Super-Fast TB3 FCPX editing volume)
Bays 1-6 = 3 x Samsung 1TB EVO 960 SATA and 3 x Seagate 10TB IronWolf (RAID 5 + Qtier)
QNAP TR-004 - Backup device including RTRR for RAID 0 volume
JBOD = 1 x Seagate 10TB IronWolf 1 x Seagate 6TB IronWolf
Re: TVS-672XT Slow 10GBase-T Read Speed
Thanks for that, but I think my issue is different. I'm not using a built-in Apple 10GbE adapter but the one built in to my Akitio Thunder 3 dock. iPerf3 tests report my MacBook (via the dock) to QNAP bandwidth (both ways) is 9.35Gbits/sec (probably as good as 10GbE gets), so I'm confident it isn't the Akitio or QNAP 10GbE hardware causing this problem.
I done some more tests but this time created a new non-QTtier share (the tests above were to a Qtier share) and this time tested using SMB, AFP, NFS and Thunderbolt 3.
SMB: 600Mbps Write / 450Mbps Read (+/- 50Mbps)
AFP: 600Mbps Write / 800Mbps Read (+/- 50Mbps)
NFS: 660Mbps Write / 680Mbps Read (very consistent)
Thunderbolt 3: 720Mbps Write / 1320Mbps Read (very consistent)
I ran Black Magic many times for each connection type but there was very little variation.
SMB is the worst performing for Read by some margin with NFS / Thunderbolt 3 being the most consistent. I don't know what's going on but I'm quite sure it isn't the 10GbE hardware.
Fixed it. SMB is now running as it should
For those interested, I removed Qtier, deleted the Virtual LAN switch and rebooted. On startup I re-enabled the Virtual LAN switch and setup Qtier again making sure to enable Jumbo frames on the QNAP and MacBook.
Hi,onesmallstep1966 wrote: ↑Wed Jan 22, 2020 11:28 pm Fixed it. SMB is now running as it should
Thanks for the feedback.
I'm having quite the same issue but I don't use qtier.
But my question is, how did you delete and re-enable virtual switch ?
Thanks a lot !
Hello
It seems problem comes from macOS Catalina. I've just installed Big Sur from scratch, and problem has disappeared !
I will check in the next few days...
