Tripp Lite UPS
weiyu
Tripp Lite UPS
Post by weiyu »
Anyone use Tripp Lite UPS connect with QNAP? This is not in the compatible list. Just want to know if there is power outage then this NAS can detect it to have safe shutdown through USB cable. I just bought a new QNAP TS-453Be.
Tripp Lite SmartPro 230V 1.5kVA 900W Line-Interactive UPS, Tower, LCD, USB, 8 Outlets
https://www.tripplite.com/smartpro-230v ... MX1500LCDT
Postman99
Re: Tripp Lite UPS
Post by Postman99 »
Bump ?
Ts-453Pro 4.21 with 4xWD red 4tb
moody_blue
Easy as a breeze
Re: Tripp Lite UPS
Post by moody_blue »
QNAP uses this driver to communicate with usb UPS https://networkupstools.org/docs/man/usbhid-ups.html
You can check in this table https://networkupstools.org/stable-hcl.html what driver your UPS requires in NUT. If it's usbhid-ups probably it is supported by QNAP. If it requires another driver probably you need to connect the ups to another device (such as a RasPI) and QNAP will recognize it.
In my case, even though my UPS is supported by QNAP, I prefer to have it connected to my router (running OpenWrt).
QNAP TS-253A 8G QTS 5.0.1.2145
Plex Media Server 1.29.0.6209
OpenHAB 3.4.0.M2
Unifi 7.2.92
Apache80 2454.8230
GLPI 10.0.3
