Hello
I have an old but high quality APC Smart-UPS 1500VA (SUA1500i) at home, thinking of replace the battery to use it with QNAP TVS-463.
I have checked from compatibility list, it only shows the update model of this one called SMT1500.
Is there any chance that the UPS not listed in compatibility chart will be discovered by QNAP so I could setup shutdown instruction?
Thank You
UPS not listed in compatibility list
- OneCD
Re: UPS not listed in compatibility list
Yes, there's a chance. Try it and see.
I tried and it's work!! QNap recognized it and about a year now I have been using it without any issue.
Thanx for suggestion OneCD
