Feb 4 19:49:25 XXXNAS RULE=9 ACT=DROP IN=br1 OUT= MAC=01:00:5e:7f:ff:fa:00:18:dd:08:1b:32:08:00 SRC=169.254.168.151 DST=239.255.255.250 LEN=302 TOS=00 PREC=0x00 TTL=4 ID=60053 DF PROTO=UDP SPT=1900 DPT=1900 LEN=282 MARK=0
SiliconDust's Support site has an article called "UPnP Multicast Send Unicast Recv Test" where it says:
Technical information about the test:
HDHomeRun Setup send a series of SSDP M-SEARCH packets to the 239.255.255.250 multicast group.
If received by the HDHomeRun the HDHomeRun responds with a unicast SSDP response.
The expected response was not received by the PC running HDHomeRun Setup.
I'm not well versed in this type of stuff, and would appreciate any ideas on creating a new QuFirewall rule that doesn't open anything up and eliminates the warnings.
