Bluetooth receiver drivers
jeffski10
Post by jeffski10 » Sat Apr 17, 2021 6:37 pm
I've been looking to get some Bluetooth sensors feeding into my Home Assistant install so I can monitor my house plants. Adding on a USB bluetooth device works in that its recognised but the driver is missing. Has anyone been able to add such device or compile a driver in the past to get this working?
# lsusb; dmesg | egrep -i 'blue|firm'; uname
Bus 001 Device 003: ID 1005:b155 Apacer Technology, Inc.
Bus 001 Device 004: ID 0bda:8771 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 1c05:2074
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 1c04:0012 QNAP System Inc.
Bus 002 Device 002: ID 1c05:3074
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
[ 0.777120] Bluetooth: Core ver 2.22
[ 0.785005] Bluetooth: HCI device and connection manager initialized
[ 0.792007] Bluetooth: HCI socket layer initialized
[ 0.797005] Bluetooth: L2CAP socket layer initialized
[ 0.802014] Bluetooth: SCO socket layer initialized
[ 12.032103] Bluetooth: hci0: rtl: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 12.040715] Bluetooth: hci0: rtl: loading rtl_bt/rtl8761a_config.bin
[ 12.047088] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761a_config.bin failed with error -2
[ 12.056228] bluetooth hci0: Falling back to user helper
[ 74.720095] Bluetooth: hci0: rtl: loading rtl_bt/rtl8761a_fw.bin
[ 74.726148] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761a_fw.bin failed with error -2
[ 74.734940] bluetooth hci0: Falling back to user helper
[ 136.160095] Bluetooth: hci0: Failed to load rtl_bt/rtl8761a_fw.bin
[ 303.136730] [S84bluetooth] start
[ 303.137307] [S84bluetooth] end
[ 303.495195] Bluetooth: RFCOMM TTY layer initialized
[ 303.500098] Bluetooth: RFCOMM socket layer initialized
[ 303.505486] Bluetooth: RFCOMM ver 1.11
[296626.690944] Bluetooth: hci0: rtl: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[296626.699659] Bluetooth: hci0: rtl: loading rtl_bt/rtl8761a_config.bin
[296626.706157] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761a_config.bin failed with error -2
[296626.715391] bluetooth hci0: Falling back to user helper
[296672.690150] Bluetooth: hci0: rtl: loading rtl_bt/rtl8761a_fw.bin
[296672.696303] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761a_fw.bin failed with error -2
[296672.705186] bluetooth hci0: Falling back to user helper
[296672.710651] Bluetooth: hci0: Failed to load rtl_bt/rtl8761a_fw.bin
