[TS531P] RAM upgrade
stanzani
Know my way around
Post by stanzani »
I have a 2G RAM module (2G 1Rx8 DDR3L 1600 SO from Transcend. How do I make sure this is suited from the NAS in the subject?
I did not find any solid rock information in the web or forum
TS-531P Annapurna
Toxic17
Ask me anything
Contact:
Re: [TS531P] RAM upgrade
Post by Toxic17 »
so spec info:
System memory:
TS-531P-2G: 2GB DDR3-1600 RAM (1 x 2GB)
TS-531P-8G: 8GB DDR3-1600 RAM (1 x 8GB)
Total memory slots:2 SODIMM
Memory expandable up to: 16 GB (2 x 8GB)
(*For dual-DIMM configurations, you must use a pair of identical DDR3 RAM modules.)
QNAP Accessory store shows one SO-DIMM with this spec: QNAP 4GB DDR3-1600 204Pin RAM Module SODIMM
there is no "L" associated with that so I guess it is standard DDR3 and not DDR3 low voltage.
Perhaps taking out the original DIMM will tell you exactly what type you require.
https://shop.qnap.com/index.php?route=p ... uct_id=256
https://shop.qnap.com/index.php?route=p ... uct_id=135
https://shop.qnap.com/index.php?route=p ... uct_id=257
https://shop.qnap.com/index.php?route=p ... uct_id=126
Regards Simon
Qnap Downloads
MyQNap.Org Repository
