for hdd you can remove them and insert into a pc or a hdd dock then use disk management to remove the partitions.
but then what about m.2 ssds? this requires more hassle to remove. also what if you don't have a pc that does m.2 ssds? is there an alternative for removing the partitions on them, to perform a clean reinstall for qts ?
seems there are m.2 dockers out there, but i don't have one of those
https://shopee.com.my/Blueendless-Type- ... 3189345063
how to remove partitions from m.2 ssd?
- Moogle Stiltzkin
NAS
Network
Resources
Network
Resources
- Been there, done that
Re: how to remove partitions from m.2 ssd?
If you have a SATA docking or SATA to USB cable, buy a ngff ssd adapter.
1x TS251, 1x TS251D, 1x TS253
- jaysona
fdisk works, just delete the partition, it doesn't get much simpler and more basic than that.
admin@871p:[~]# fdisk /dev/nvme0n1
The number of cylinders for this disk is set to 121601.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): p
Disk /dev/nvme0n1: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/nvme0n1p1 1 121602 976762583+ ee EFI GPT
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
- Moogle Stiltzkin
thx both for the suggestions. you are both correct.
https://askubuntu.com/questions/932331/ ... of-dev-sda
should i bother doing this to double check i am doing for the correct device partitions?
i'm using m.2 sata ssds on this system, so i guess i should be looking for the 500gb sized /dev/sd[a-z] devices?
i think i'll go with the fdisk command (i did google and notice this but wasn't sure, because the nas in discussion was a legacy model, and not too familiar with the command). thats the one i was wondering about, whether it could be done while the m.2 ssd was residing in the nas.
Right now i am in the midst of doing a reinitiatializing of my main nas (ts-877), so i am just checking through all the steps for the process.
One thing i didn't do was remove the m.2 ssd and the hdds. Instead i just left it inside, and just did the reinitialization. Because they said reinit will clear the partitions supposedly.
I definitely do not have malware on my nas, so i did not reckon i needed the extra step for removing partitions off device (e.g. hdd docker), that's why i skipped that part.
I just wanted to check if my backups work, and whether i can fix this odd issue i am having in HBS. If it doesn't fix it, i may try that fdisk method mentioned to see if that does the trick (as well as removing the hdds to remove partitions, although not sure what this accomplishes, because my qts system is installed on the 2 x m.2 ssd raid1 to begin with.
viewtopic.php?f=45&t=155142&start=30#p788346
however i just wanted to point out, at the time of m.2 ssd instalation, i had mistakenly put the sticky part of the thermal padding onto the m.2 ssd, which to my current understanding is the wrong thing to do. Should have stuck sticky end onto the metalic heatsink, and just relied on the clips for pressing it against the pads. Doing it this way then makes removal of m.2 ssds much easier in situations where you need to remove it later. lesson learned for next time
The first thing you need to do after installing a new SSD or hard disk is to partition it. A drive needs to have at least one partition before you can format it and store files on it.
In Linux, there are several tools that you can use to create partitions, with fdisk being the most commonly used one.
In this article, we will talk about the fdisk command.
fdisk is a menu-driven command-line utility that allows you to create and manipulate partition tables on a hard disk.
Be aware that fdisk is a dangerous tool and should be used with extreme caution . Only root or users with sudo privileges can manipulate the partition tables.
https://linuxize.com/post/fdisk-command-in-linux/Generally, SATA device names follow the pattern /dev/sd[a-z], while NVMe device names have the following pattern /dev/nvme[1-9]n[1-9]
By the way, the command lsblk or lsblk -f can help you a lot to get a quick overview of your disk and partitioning structure and to look up the device names.
will consider this in future.
NAS
Network
Resources
Network
Resources
- jaysona
Fdisk is only dangerous in the hands of those that have no clue what they are doing. Fdisk is not more dangerous than the "format" command is on Windows.
will list all the devices installed, you will then need to use fdisk to delete the portions on the disk(s) you want wipe.
viewtopic.php?t=157625&p=768991#p768913
fdisk -l
This has been explained already.however i just wanted to point out, at the time of m.2 ssd instalation, i had mistakenly put the sticky part of the thermal padding onto the m.2 ssd, which to my current understanding is the wrong thing to do. Should have stuck sticky end onto the metalic heatsink, and just relied on the clips for pressing it against the pads. Doing it this way then makes removal of m.2 ssds much easier in situations where you need to remove it later. lesson learned for next time
