TS-1685 M.2 cache needs to be replaced.
bs98909
Post by bs98909 »
I have an M.2 SSD which is being used as my cache. I cannot just replace it thinking that the system would just detect the change and re-initalize the drive as cache. Nope just just tells me that the PPOL is now degraded and there doesn't seem to be a means to just initialize it and add it. So I put the old drive in which is "heathy" but its life is now at ZERO %.
I must be missing a step. I cannot just bring up "Storage & Snapshots" and just "detach" the ZERO Life drive.
HELP!
Cheers!
B-
Details:
TS-1685 - 64 GB (~62 GB usable) RAM - 25TB RAID6 (4x SanDisk Ultra II 240GB SSD, 8x Seagate ST2000VN004 2TB HHD, 4x Seagate ST8000VN0022 8TB HHD) - 4x 1GB NIC
Firmware version	4.4.1.1146 Build 20191206
CPU	Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz (4 cores, 8 threads)
# cat /etc/os-release
NAME="QTS"
VERSION="4.4.1 (20191206)"
ID=qts
PRETTY_NAME="QTS 4.4.1 (20191206)"
VERSION_ID="4.4.1"
dolbyman
Re: TS-1685 M.2 cache needs to be replaced.
Post by dolbyman »
Never use a single drive for write cache.
The only way to replace it, is to remove the cache (data gets destaged) and then add a new one (from then on RAID1+ please)
https://docs.qnap.com/nas-outdated/QTS4 ... 25FAC.html
bs98909
Post by bs98909 »
It is "read-only" — I tried to just diable the cache but did find out through trial and error that I had to remove the cache altogether, then shutdown, swap the M.2 SSD and then add the read-only cache again. I am not testing.
Thank you for the link. I'll check that out now.
Cheers!
B-
Details:
NAME="QTS"
ID=qts
VERSION_ID="4.4.1"
