Can't play videos via GPU passthrough
subzero155
Getting the hang of things
Post by subzero155 »
I have Nvidia 1060 GPU installed in my QNAP TVS-682.
I am trying to use the GPU on the VM passthrough. I have Windows 10 installed as a VM Although I can see the driver installed in Windows, videos play extremely slow if they play all, including YouTube videos. Also the sound is distorted and too slow.
The Nvidia GPU and Kernel drivers are installed from QNAP app centre.
I have tried to update/reinstall the Nvidia driver on Windows but this has not sorted out the problem.
Any suggestions are appreciated.
Trexx
Ask me anything
Post by Trexx »
Verify installed latest virtio drivers and have vm configured to use them for nw, hdd, etc.
Make sure enough Cpu & memory for VM (I run my win10 at 4x8).
Paul
UPS: CP AVR1350
subzero155
Re: Can't play videos via GPU passthrough
Trexx wrote: Tue May 11, 2021 9:52 am Verify installed latest virtio drivers and have vm configured to use them for nw, hdd, etc.
I am using 32GB of RAM and i7 passthrough. Videos work well without the GPU.
dolbyman
Post by dolbyman »
unless you have swapped the processor, the i7 is NOT passthrough (because your nas either has a pentium or an i3)
subzero155
dolbyman wrote: Tue May 11, 2021 7:33 pm unless you have swapped the processor, the i7 is NOT passthrough (because your nas either has a pentium or an i3)
Yes, I have upgraded to i7.
