Qnap TS-1079 Pro HDD compatability
markusha
Post by markusha »
Hello
i own Qnap 1079 pro
i sold all my 10 3TB HDD's and upgrading to new HDD's
I seen Compatibility List
Qnap compatability list shows up to 12TB per HDD
But item description shows
supports up to 10 hdd's 3TB per HDD each
so does it support 6-10 or 12TB or only 3TB max per HDD
Thank you
QNAP TS-1079 Pro
NAS Intel® Xeon® E3-1275 4GHz CPU
16GB RAM
dolbyman
Re: Qnap TS-1079 Pro HDD compatability
Post by dolbyman »
If you run 4.3 firmware, your NAS should support storage pools, so only inode size should limit your volumes max storage
markusha
Post by markusha »
Does it mean running v4.3 i can stick lets say 10TB hdd and it works as it has to
dolbyman
Post by dolbyman »
it should
markusha
Post by markusha »
ill do test with higher thasn 3tb hdd
