Hi All,
I'm looking at getting a new NAS and deciding between my first x86 NAS, or sticking with an ARM unit. The TS-431K has an AL-214 CPU, and the TS-431X3 has an AL314 CPU.
The CPU specs (4-core 1.7GHz) for those two NAS's seem identical? And I'm finding it difficult to find any info on either CPU. Is there a difference? Power usage maybe?
I'm currently on a TS-419Pii - which is still going well, but looking to upgrade due to it's age.
Thanks.
AL-214 vs AL-314 CPU
Re: AL-214 vs AL-314 CPU
I can't find any references to AL-214 except from Qnap so it's hard to tell. If the Qnap specifications are correct the differences are probably very small.
I doubt that it's noticeable.Power usage maybe?
I'd make my decision based on other metrics like price, RAM (if you intend to install apps and/or containers) and the number and type of network interfaces.
Huge upgrade in more ways than the CPU.I'm currently on a TS-419Pii - which is still going well, but looking to upgrade due to it's age.
