Upgrading RAM for TVS-672x
I’m looking at getting an TVS-672x and I’m going to want more RAM but I’m not sure if I absolutely need to buy RAM from QNAP or a special kind of Ram or will any DDR4 SO-DIMM will do?
Re: Upgrading RAM for TVS-672x
I have the same question. Did you figure out the answer? Anyone?
CT32G4SFD8266 fits to my 672n so fits to X.
Thanks - seems I wasn't configured to receive a notification when a reply is posted, so just saw this now.
I already ordered two CT16G4SFD832A and hope they are compatible...
Confused: the TVS-x72X doesn't support ECC memory?
[Main Server]
QNAP TS-872X7 (QuTS)
PCIe Gen3 x4: QNAP QM2-2P-344 with 2 x 2TB XPG SX8200 Pro NVMe
8 x WD102KFBX 10TB Red Pro, RAID6
[Backup]
TS-128A
18TB WD181KFGX Red Pro
[Backup]
TS-128A
Did it work? Was the CT16G4SFD832A module compatible with TVS-672x?I already ordered two CT16G4SFD832A and hope they are compatible...
Have been unable to confirm: TVS-872XT has been hanging intermittently. QNAP said to remove unsupported RAM so I've been testing using Stock RAM that came with unit, but still hanging intermittently. Until cause is identified and resolved, I'm unable to test and confirm that CT16G4SFD832A doesn't also cause intermittent hanging.
[Main Server]
[Backup]
TS-128A
[Backup]
TS-128A
I upgraded my TVS-672X with 2x32 GB blocks from Kingston and it works without a glitch (2 weeks of testing). The only thing I noticed was the first boot after upgrading took a bit longer than usual and the Control Panel showed 64GB installed with 0 GB available for roughly 5-6 minutes; afterwards everything ok.
Kingston's compatibility search can be accessed here: https://www.kingston.com/en/memory
The original 8 GB block was from Transcend
Kingston ValueRAM 32GB 2666MHz DDR4 NonECC CL19 SODIMM 2Rx8 1.2V KVR26S19D8/32
