Hi all
I have been getting my hands on the old QNAP TS-209 Dual Disk NAS system and I want to configure it. But I cannot find the firmware required to set it up anywhere on the internet.
Can you please provide me with a download link for the latest TS-209 firmware?
Thanks and best regards
Where can I donwload the firmware needed to set up a QNAP TS-209?
Re: Where can I donwload the firmware needed to set up a QNAP TS-209?
Hi cool thank you, it worked. The download folder on their page, I found it with the Google Translate function that is integrated into Google Chrome.
https://qnap.ru/support/download
Does someone keep a copy of this cause i'm stuck with a stock v1 firmware !
- Easy as a breeze
Someone gave you the link already !!!
In the only other topic you posted !
viewtopic.php?f=73&t=169817&p=841739#p841739
Not to mention that you have the same answer above your reply!!!
