in the Disk SMART menu, "Summary" is good ("No errors were detected on disk. Your disk should be operating properly"). "SMART information" also does not show any errors.
Rapid tests are also ok, but complete test gives "read failure" for disk 1 (successful for disk 2). other than that, I haven't noticed any errors.
Is that disk failing? How can I run more detailed tests to check both drives ("smartctl -t long", or are there any better options)?
I have also installed command-line smartctl, not sure if this is correct:
[~] # smartctl -a -d ata /dev/sda
smartctl 7.2 2020-12-30 r5155 [armv5tel-linux-3.4.6] (localbuild)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: WDC WD60EFRX-68MYMN1
Serial Number: W -DXW124DC5670Z
LU WWN Device Id: 5 0014ee 2b6d433e2
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5700 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Jun 11 19:45:44 2021 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: ( 3824) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 692) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 194 184 021 Pre-fail Always - 9275
4 Start_Stop_Count 0x0032 091 091 000 Old_age Always - 9688
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 035 035 000 Old_age Always - 47830
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 18
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 13
193 Load_Cycle_Count 0x0032 169 169 000 Old_age Always - 95453
194 Temperature_Celsius 0x0022 112 091 000 Old_age Always - 40
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 5
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 47830 45376360
# 2 Short offline Completed without error 00% 47830 -
# 3 Short offline Completed without error 00% 47814 -
# 4 Extended offline Completed: read failure 90% 47814 45376360
# 5 Extended offline Completed: read failure 90% 47797 45376360
# 6 Short offline Completed without error 00% 47790 -
# 7 Extended offline Completed: read failure 90% 47790 45376360
# 8 Short offline Completed without error 00% 47766 -
# 9 Extended offline Completed: read failure 90% 47765 45376360
#10 Short offline Completed without error 00% 47765 -
#11 Extended offline Completed: read failure 90% 47764 45376360
#12 Short offline Completed without error 00% 47742 -
#13 Short offline Completed without error 00% 47718 -
#14 Short offline Completed without error 00% 47694 -
#15 Short offline Completed without error 00% 47670 -
#16 Short offline Completed without error 00% 47647 -
#17 Short offline Completed without error 00% 47623 -
#18 Short offline Completed without error 00% 47599 -
#19 Extended offline Completed: read failure 90% 47575 45376360
#20 Short offline Aborted by host 90% 47575 -
#21 Short offline Completed without error 00% 47551 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
