TVS-872X - Fast write but slow read speed 8x Exos X16
Houbi
Post by Houbi »
Hello everyone
I am facing a weird issue. I get write speeds of about 850MB/s to 950MB/s but only 650MB/s read (from/to the 8 disk RAID6). I get 1.15GB/s write and read from my SSD RAID10. Tried with and without NVMe Caching. Testing client source drives, switches etc. are easily capable to handle 1.15GB/S read/write.
QNAP: TVS-872X
OS: QuTS hero h.4.5.3.1670
RAM: 32GB (2x16GB, Crucial. Swapped to original no change)
System/Apps: Samsung 980 Pro in RAID1 (in QM2-4P-384 Controller)
SSD: 4 x Samsung Evo 860 2TB in RAID10 (in QM2-4S-240 Controller)
HDD: 8 x Seagate Exos 14TB X16 in RAID6 (latest Firmware)
Cache: 2 x Samsung Evo 970 Plus 1TB (1.78TB read, 10GB ZIL, in QM2-4P-384 Controller)
Network: 10GbE, Static IP, MTU 9000, all Switches Jumbo Frames enabled, network is fine
Dedup is off, compression/caching on or off does not matter. IOTop shows between 1400MB/s and 1600MB/S while doing the read tests, but only 650MB/s arrive on my client.. Any ideas about how to troubleshoot this are highly welcome.
Thank you,
Houbi
qrusher
Know my way around
Contact:
Re: TVS-872X - Fast write but slow read speed 8x Exos X16
Post by qrusher »
do you have any SSD cache enabled?
ssh to the NAS and run the following commands. this should work on your NAS.
also
qcli_storage -d
qcli_storage -T force=1
qcli_storage -t force=1
post the reports that come out of the NAS. this will show what your RAID's performance is capable of.
crush qnaps like a thanos crushing planets
Updates are compromise between old bug patches and new bugs introduced. 8)
do you backup..then kill it with fire
stuff:mikrotik Crs309-1g-8s+in & s+rj10 x4
Houbi
Post by Houbi »
qrusher wrote: Sat Jun 19, 2021 12:32 am
also
qcli_storage -d
THX man. One of my Exos drives just died last night, will have to wait for a replacment first. Will update the thread later on
Houbi
Post by Houbi »
qcli_storage -d
Enclosure Port Sys_Name Type Size Alias Signature Partitions Model
NAS_HOST 1 /dev/sdk HDD:data 12.73 TB Disk 1 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 2 /dev/sdl HDD:data 12.73 TB Disk 2 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 3 /dev/sdf HDD:data 12.73 TB Disk 3 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 4 /dev/sde HDD:data 12.73 TB Disk 4 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 5 /dev/sdd HDD:data 12.73 TB Disk 5 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 6 /dev/sdc HDD:data 12.73 TB Disk 6 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 7 /dev/sdb HDD:data 16.37 TB Disk 7 -- 5 Seagate ST18000NM000J-2TV103
NAS_HOST 8 /dev/sda HDD:data 12.73 TB Disk 8 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST P1-1 /dev/nvme0n1 SSD:cache 931.51 GB PCIe 1 M.2 SSD 1 -- 6 Samsung SSD 970 EVO Plus 1TB
NAS_HOST P1-2 /dev/nvme1n1 SSD:cache 931.51 GB PCIe 1 M.2 SSD 2 -- 6 Samsung SSD 970 EVO Plus 1TB
NAS_HOST P1-3 /dev/nvme2n1 SSD:data 465.76 GB PCIe 1 M.2 SSD 3 -- 5 Samsung SSD 980 PRO 500GB
NAS_HOST P1-4 /dev/nvme3n1 SSD:data 465.76 GB PCIe 1 M.2 SSD 4 -- 5 Samsung SSD 980 PRO 500GB
NAS_HOST P2-1 /dev/sdh SSD:data 1.82 TB PCIe 2 M.2 SSD 1 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-2 /dev/sdg SSD:data 1.82 TB PCIe 2 M.2 SSD 2 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-3 /dev/sdi SSD:data 1.82 TB PCIe 2 M.2 SSD 3 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-4 /dev/sdj SSD:data 1.82 TB PCIe 2 M.2 SSD 4 -- 5 Samsung SSD 860 EVO M.2 2TB
fio test command for physical disk: /sbin/fio --filename=test_device --direct=1 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
Start testing!
Performance test is finished 100.000%...
Enclosure Port Sys_Name Throughput Type Size Alias Signature Partitions Model
NAS_HOST 1 /dev/sdk -- HDD:data 12.73 TB Disk 1 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 2 /dev/sdl -- HDD:data 12.73 TB Disk 2 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 3 /dev/sdf -- HDD:data 12.73 TB Disk 3 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 4 /dev/sde -- HDD:data 12.73 TB Disk 4 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 5 /dev/sdd -- HDD:data 12.73 TB Disk 5 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 6 /dev/sdc -- HDD:data 12.73 TB Disk 6 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST 7 /dev/sdb -- HDD:data 16.37 TB Disk 7 -- 5 Seagate ST18000NM000J-2TV103
NAS_HOST 8 /dev/sda -- HDD:data 12.73 TB Disk 8 -- 5 Seagate ST14000NM001G-2KJ103
NAS_HOST P1-1 /dev/nvme0n1 -- SSD:cache 931.51 GB PCIe 1 M.2 SSD 1 -- 6 Samsung SSD 970 EVO Plus 1TB
NAS_HOST P1-2 /dev/nvme1n1 -- SSD:cache 931.51 GB PCIe 1 M.2 SSD 2 -- 6 Samsung SSD 970 EVO Plus 1TB
NAS_HOST P1-3 /dev/nvme2n1 -- SSD:data 465.76 GB PCIe 1 M.2 SSD 3 -- 5 Samsung SSD 980 PRO 500GB
NAS_HOST P1-4 /dev/nvme3n1 -- SSD:data 465.76 GB PCIe 1 M.2 SSD 4 -- 5 Samsung SSD 980 PRO 500GB
NAS_HOST P2-1 /dev/sdh -- SSD:data 1.82 TB PCIe 2 M.2 SSD 1 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-2 /dev/sdg -- SSD:data 1.82 TB PCIe 2 M.2 SSD 2 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-3 /dev/sdi -- SSD:data 1.82 TB PCIe 2 M.2 SSD 3 -- 5 Samsung SSD 860 EVO M.2 2TB
NAS_HOST P2-4 /dev/sdj -- SSD:data 1.82 TB PCIe 2 M.2 SSD 4 -- 5 Samsung SSD 860 EVO M.2 2TB
fio test command for File system: /sbin/fio --filename=test_device/qcli_storage --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 --size=128m &>/tmp/qcli_storage.log
Start testing!
VolID SharedFolderName Pool Mapping_Name Mount_Path FS_Throughput
2 Public 1 zpool1/zfs2 /share/ZFS2_DATA ▒4@
3 Folder 3 zpool3/zfs18 /share/ZFS18_DATA ▒4@
4 Folder 2 zpool2/zfs19 /share/ZFS19_DATA ▒4@
5 Folder 3 zpool3/zfs20 /share/ZFS20_DATA ▒4@
6 Folder 3 zpool3/zfs21 /share/ZFS21_DATA ▒4@
7 Folder 3 zpool3/zfs22 /share/ZFS22_DATA ▒4@
8 Folder 3 zpool3/zfs23 /share/ZFS23_DATA ▒4@
9 Folder 3 zpool3/zfs24 /share/ZFS24_DATA ▒4@
10 Folder 3 zpool3/zfs25 /share/ZFS25_DATA ▒4@
11 Folder 3 zpool3/zfs26 /share/ZFS26_DATA ▒4@
12 Folder 3 zpool3/zfs27 /share/ZFS27_DATA ▒4@
13 Folder 3 zpool3/zfs29 /share/ZFS29_DATA ▒4@
14 Folder 3 zpool3/zfs30 /share/ZFS30_DATA ▒4@
15 Folder 3 zpool3/zfs31 /share/ZFS31_DATA ▒4@
16 Folder 3 zpool3/zfs32 /share/ZFS32_DATA ▒4@
17 Folder 3 zpool3/zfs33 /share/ZFS33_DATA ▒4@
18 Folder 3 zpool3/zfs34 /share/ZFS34_DATA ▒4@
19 Folder 3 zpool3/zfs35 /share/ZFS35_DATA ▒4@
20 Folder 1 zpool1/zfs36 /share/ZFS36_DATA ▒4@
I also opened up a case with QNAP, after back and forth for a while they today opened up a developers ticket for this case.
Best,
Houbi
