2 questions on possible upgrades for the 853U:
- can I go over 8GB RAM?
- is it possible to replace the Celeron with a faster CPU with the same socket?
Thanks!
TS-853U RAM & CPU upgrades
Re: TS-853U RAM & CPU upgrades
-try it ..some report success with 16GB (outside of the given spec)
-it's soldered not socketed
If some reported success, I'll try it and report back here. Thanks!
I tried a Crucial RAM CT2KIT102464BF160B 16GB Kit (2x8GB) DDR3 1600 MHz CL11 kit but it didn't work... maybe there are different revisions for the motherboards...
After I re-seated the original SODIMMs inthe QNAP it now refuses to boot with all HDD LEDs red and the boot led blue, any ideas?
Did you ground yourself before touching any NAS parts ? .. if your are unlucky you killed your NAS by ESD
https://en.wikipedia.org/wiki/Electrostatic_discharge
Lets hope that's not so frequent... any other ideas?
Besides a spontaneous LPC death or your device (fixable with a 100Ohm resistor) .. not much comes to mind (even more so as it worked before the RAM swap, so something happened there)
