Hi all. Long time user of Unraid NAS. I am wondering how low powered NAS can do virtualization, specially if they are ARM powered. In Unraid, if my processor is powerful enough, you can create a gaming VM, with GPU passthrough. For Qnap low powered NAS, are they talking about the same thing? Or is it that the Host is on a different NUC/ Lenovo Tiny device, and have the vdisk on Qnap?
Been reading a lot about Qnap lately, and the built-in software, QTS & QuTS Hero. I'm beginning to see value that it provides. Doing more research, hence the question.
Low Powered Qnap for virtualization
Re: Low Powered Qnap for virtualization
ARM NAS don't support VM's at all, only limited containers
The consumer Celeron NAS are very limited in terms of virtualization power (low power Celerons)
If you want most bang for the buck you would run virtualization on a standalone server (maybe even second hand Xeon) and not on a NAS
Yes, they don't support VMs running on the NAS. Is it possible to have your VMs on an Intel NUC, Lenovo Tiny, and have Vdisk(?) stored on the ARM NAS? Compute is being done by NUC or Tiny, while the Vdisk is on the ARM NAS via iSCSI?
Sure ..both ARM and x86 NAS support ISCSI
- Moogle Stiltzkin
celerons are low power... but in terms of vm i'd suggest the amd ryzen cpus.
the x73a has low power cpu with many threads. but the nas not sure if it's in your budget.
keep in mind that the power usage isn't just your cpu, it's also the other components in the nas like HDDS etc, they all add up to total power usage.
check the part specs their watt usage, then use an electricity calculator to get a rough estimate for annual electricity bill costs.
For people measuring existing equip they already own, there are some power meters you can use that will monitor your actual power usage to get the values to then use to calculate your annual bill
ssds are low powered but in terms of price per gig they are more costlier than hdds.
NAS
Network
Resources
Network
Resources
I actually am an Unraid user. I dictate what CPU to use, as I built the box myself. I'm seeing myself liking the apps of Qnap, which I don't have in Unraid. My current NAS has quite a bit of processing power. But I don't need all that now. All I need is probably 2 VMs, 1 Linux, 1 Windows. Coming from a powerful NAS, going to Qnap, the processing power is quite a drop. If I'm buying Qnap, I'm sure the processing power won't come near to what I have before.
@dolbyman mentioned above that iSCSI is supported. Are there any other ways to have host on a different box, and disks on the Qnap apart from using iSCSI?
@Moogle Stiltzkin, I don't want to rely on the cpu power of the NAS itself, as I fear if I'm going to use a virtual desktop on the NAS, user experience may not be good.
