Graphics Driver
honkin
Getting the hang of things
Graphics Driver
Post by honkin »
I just wanted to check how one updates the graphics driver on a TS-451, or is that all looked after with firmware updates?
cheers
dolbyman
Re: Graphics Driver
Post by dolbyman »
graphics for what? transcoding or the (ill advised) build in hdmi out via hdstation or qvpc ?
honkin
Re: Graphics Driver
Post by honkin »
ah, I may have misunderstood what I read.
The machine is struggling to play h.265 encoded videos via the latest Kodi. A thread at the Kodi forum mentioned upgrading the driver of the graphics card to possibly help, so I was assuming the driver for the Intel GPU of the NAS.
dolbyman
Re: Graphics Driver
Post by dolbyman »
I think Baytrail Graphics does not support x265 hardware decode
https://www.notebookcheck.net/Intel-HD- ... 037.0.html
So forget the NAS as a player and buy a cheap android kodi box that supports it ...will work much better
honkin
Re: Graphics Driver
Post by honkin »
cheers and thanks for your reply
The weird thing about your comment on support for x265 hardware decode is in Kodi Matrix 19.0, audio is fine, but the video is some odd fine pattern, yet when I went back and opened Kodi Leia up, it played the video, at least until half way through, when it then stopped, so not sure how that occurred
Will have a look at maybe something like the Skystream Pro 8k or something
cheers
