A short while after upgrading from 4.5.3 to 4.5.4 the system now cannot see my 2nd HD (checked other disks), the temperature of the System just reads 0 and the fan speed shows as some really large number. I've downgraded back to 4.5.3 but the system still is showing odd hardware issues. I did have this happen once before and the downgrade cleared it up.
Just wonder if this is software or could it actually be hardware related. The system is still running as expected off of the single drive in slot 1.
Rick
TS-251+ - Hardware issues after FW upgrade
Dual QNAP TS-251+
Re: TS-251+ - Hardware issues after FW upgrade
sounds like the lpc bug of your dying nas cpu... search the forum for the resistor fix
