Hello everyone,
I would like to replace the fan in my TS-453mini.
I was able to successfully remove the bottom plastic seat, but I have no idea how to detach the top plastic case that holds and blocks the fan inside.
Inspected the QNAP Hardware Manual, but sadly it does not have the section on TS-453mini fan replacement.
Do you know if there is a possibility to download a technical manual, which would show how is the plastic case attached?
Thanks!
Re: TS-453mini fan replacement
No technical/service manuals have ever seen the light of day (that I know of)... so only QNAP would know (and they do not come here)
Have you checked if any online reviews took it apart ?
this one looks like the top lifts up rather than the bottom
https://www.eteknix.com/qnap-ts-453-mini-nas-review/2/
This is very helpful, thanks a ton!
I did search the youtube, google and so on for dismounting the mini - but it seems to no avail.
Will try to look closer on how the case is mounted.
Did you do this in the end?
I'd really like to swap my fan!
