Hello, can anyone tell me if any of the DDR4 ECC available, like in the next link's in the message, is compatible with QNAP TVS-672XT?
32GB DDR4 PC4-21300 2666Mhz 260-pin SODIMM ECC Unbuffered Memory RAM
Kingston 32GB DDR4-2666MHZ ECC CL19 SODIMM 2RX8 MICRON E
Thanks,
DDR4 ECC compatibility
Thanks.
TVS-672XT
QTS 5.0.1.2145
TVS-672XT
QTS 5.0.1.2145
- Don
Re: DDR4 ECC compatibility
Specs for this unit say nothing about supporting ECC. Also the memory in the QNAP store for the unit is also non-ECC. So I would say the unit does not support ECC.
Hello, theoretically it supports ECC when looking at CPU spec sheet. Qnap themselves have not mentioned compatibility with ECC.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
Thanks,
Thanks,
Thanks.
TVS-672XT
QTS 5.0.1.2145
TVS-672XT
QTS 5.0.1.2145
