I purchased a used QNAP TS-809U NAS. After powering it up and waiting 24 hours two drives are in a "Warning" state. In "RAID Management" is says the status is "In degraded mode - Read only Failed Drive(s) 7". Drive 4 and 7 both show "Warning" in the "SMART Information" column of "Volume Management".
After reading a couple other posts it seems I should replace drives 4 and 7. The drive model number is WDC WD2003FYYS-02W0B0. My question is where can I buy replacement drives? I found this listing on Server Supply, but as the last part of the model number is not provided I am not sure if it is the correct drive. Is the following the correct drive?
https://www.serversupply.com/HARD%20DRI ... 123756.htm
Correct model HDD for TS-809U
Reason: removed tracking tag from link
Re: Correct model HDD for TS-809U
replace with any 2TB NAS compatible drive models(WD Black are not NAS rated)
a RAID6 should continue to work with two failures though
