Updated my NAS from 4.5.3 to 4.5.4 and now I cannot use my Nvidia GPU for Hardware Transcoding because /dev/nvidia-uvm is missing so CUDA doesn't work. Anyone else hit this and know of the fix?
Newish to QNAP but feel like I might need to slow down on the updates. I normally like to keep ontop for security fixes but seems they don't test stuff very well either. If I look in the Nvidia Driver update notes they are all about how they broke the drivers with a new firmware and now they've fixed it. I feel like I might be stuck waiting for a driver update...
/dev/nvidia-uvm missing on 4.5.4 firmware
Re: /dev/nvidia-uvm missing on 4.5.4 firmware
I'm seeing the same missing nvidia-uvm.
Any progress on this?
Anyone opened a ticket for this?
QNAP does not come here..so tickets need to be opened
Seems to be random, done a few reboots and sometimes it's there and others it's not. I'm not touching it for the moment as I've got it back working.
They really need to update the driver though also as this older driver is blocking some things from working also
so you opened a ticket?
I'm seeing the same issue on QNAP 5.0.0.1891... has there been a workaround?
the solution is posted here
https://www.reddit.com/r/qnap/comments/ ... nvidiauvm/
nvidia-uvm-init.sh:
nvidia-uvm-init.sh:
#!/bin/bash
## Script to initialize nvidia device nodes.
## https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-verifications
/sbin/modprobe nvidia
if [ "$?" -eq 0 ]; then
# Count the number of NVIDIA controllers found.
NVDEVS=`lspci | grep -i NVIDIA`
N3D=`echo "$NVDEVS" | grep "3D controller" | wc -l`
NVGA=`echo "$NVDEVS" | grep "VGA compatible controller" | wc -l`
N=`expr $N3D + $NVGA - 1`
for i in `seq 0 $N`; do
mknod -m 666 /dev/nvidia$i c 195 $i
done
mknod -m 666 /dev/nvidiactl c 195 255
else
exit 1
fi
/sbin/modprobe nvidia-uvm
# Find out the major device number used by the nvidia-uvm driver
D=`grep nvidia-uvm /proc/devices | awk '{print $1}'`
mknod -m 666 /dev/nvidia-uvm c $D 0
mknod -m 666 /dev/nvidia-uvm-tools c $D 0
else
exit 1
fi
Reason: added code tags
I had the same issue.
Turns out some of the programs are not executed in the right order so may be you should check this out:
viewtopic.php?f=320&t=133132
