I would like to run VMs on this QNap, and I know the 16GB will not be enough.
I looked at the QNap webpage. It shows some compatible RAM, but the link goes nowhere as these model may not be available at all. https://www.qnap.com/en-us/product/tvs-h1288x
I can't find what the original RAM is beside I do have 2x 8GB. These are installed in the slot 2 (channel A, DIMM 2) and slot 4 (channel B, DIMM 4). SO I guess it's correct when it goes by pair.
I understand I need some ECC RAM. But can you answer some question to help me choose a suitable RAM for this NAS ?
- Do I need UDIMM or RDIMM ?
- What is the Spec : 2G X 8 ?
- Do I need a Single or Dual Channel ?
- Do I need to get a DDR4-3200 ?
- Can I add 2x16GB or 2x32GB and work perfectly next to the 2x8GB or do I have to change all 4 RAMS ?
- A-Tech or NEMIX brand ok ? (found on Amazon, QNAP seems to be super expensive and no DDR4-3200 available, if it is necessary).
This si an example of compatible RAM from QNAP page of this model. FOr reference.
RAM-16GDR4ECK1-UD-3200
DDR type: DDR4(288PIN)
Capacity: 16GB
Spec: 2G X 8
Frequency: DDR4-3200
Form(PIN): 288PIN
with ECC Supported: ECC
Power Supply: 1.2V
Dram Organization: 2048M*72
Temperature: 0℃~85℃
