ts-h686 ports down
ts-h686 ports down
Port 3 doesnt seem to work in my new ts-h686. Thx
Re: ts-h686 ports down
More infos please
what is connected to that port
what have you tried so far
all 4 ports are connected to the modem
They are connected to a modem?
Why? What is the plan?
By connecting all 4 ports it means more speed I guess
No..connecting 4 ports to your router (I guess that is what you mean) will lead to IP address chaos..not speed improvements
You have not disclosed any troubleshooting steps you have done so far
First of all disconnect all but one (as it useless to connect all ports..as we have previously discussed)
How did you get such an idea, that connecting more ports increases network speed?
There are only very few configurations for that and I doubt, you are aware of these. If it would be so easy...
And why did you connect all ports to a modem, to increase WAN speed?
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
