Qnap 1079 and 4TB HD
Locked
paolomarino
Easy as a breeze
Post by paolomarino »
HI.
I want to buy a Qnap 1079 with 10 disks 4TB each
I want to know which is the most stable and with no problem disk.
I prefer a non enterprise disk for budget reason.
Any idea which is the king of no problem ?
Happy Qnap TS-509 Ultra (Intel E7500 + 2GB RAM + 20TB WD RED) Owner :)
Happy Qnap TS-870 Ultra (Intel I7-3770T + 16GB RAM + 64TB WD RED) Owner :)
Don
Re: Qnap 1079 and 4TB HD
Post by Don »
So you are going to spend a lot of money on a 1079 but then want to cheap out on the disks which is probably the worst place to cheap out.
For a 10 bay nas I would only trust enterprise drives with that much data but check the drive compatability list and then decide which ones to use. Google the different recommended models to see how many issues there are.
xavierh
Experience counts
Post by xavierh »
one thing is for sure... DO NOT GET SEAGATE DRIVES FOR IT.
QNAP TVS-951xQTS 5.0.0.1986 build 20220324 OS Storage Pool: Samsung 860 EVO 250GB SSD x 4 (RAID 5), Data Storage Pool: WD WD30EFRX (Red) 3TB x 4 (RAID 5), 16GB RAM WD Easystore 10TB External USB 3.0 Services: SMB, Appletalk, QPKG: Container Station, HBS 3
QNAP TS-453AQTS 5.0.0.1986 build 20220324 Services: SMB, HBS 3
Network: UDM, UDM Beacon, Unifi 8 Port Switch x 3, Flex Mini Switch, In Wall AP
P3R
Post by P3R »
Any 4 TB enterprise disk on the Qnap disk compatibility list.
I wouldn't recommend desktop disks but if you're absolutely determined, in my opinion the Hitachis on the above mentioned disk compatibility list is the only sane choice considering the manufacturer recommendations and the customer experiences reported in the forum. Although customer experiences with 4 TB disks is still limited altogether.
If you intend to use all disks in a single volume, I'd go with RAID 6 or RAID 10 and possibly online but definately offline spares as well.
paolomarino
Easy as a breeze
any info about ST4000VM000 ?
i want to put in single raid6 volume and take the 11° disk for offline spare
i need two nases in two different site with the same data on each so i need 22 disks and the difference between enterprise and standard disks are 150e each and 3.300 total. it's a lot of money :)
P3R
Post by P3R »
paolomarino wrote:any info about ST4000VM000 ?
None other that it is yet another disk not intended for NAS/RAID applications. I have read explanations of why PVR-disks are not really recommended for NAS/RAID usage on the net but I'm not sure if they are valid so google and make up your own mind.
Even when using using RAID 6, please be aware that the risks are not insignificant with such numbers of disks and huge data volumes.
...the difference between enterprise and standard disks are 150e each and 3.300 total. it's a lot of money
Yes, huge storage volumes are costly. The data on them are however usually worth much more.
When shopping for 4 TB disks in a TS-1079 in any professional environment and on a tight budget, I would today definately go with WD Se WD4000F9YZ.
If the same NAS was intended for personal use, I would also consider:
  • HDS724040ALE640 (aka H3IK40003272SW and H3IK40003272SW)
  • ST4000VN000 (yes I know it is not recommended for larger than 5 bay installations but at least it is recommended for 24*7 NAS/RAID applications)
paolomarino
Easy as a breeze
Thanks for the suggestions. I will care them.
Metzlmane
Post by Metzlmane »
HGST Ultrastar 7K4000 3TB, 4KB Sektoren, SATA 6Gb/s (HUS724030ALE640/0F14684) -> 5 years warranty
I've using this disks in RAID 10 and with no problems at all 24/7. You don't want to get cheap disks. I don't also recommend RAID 6 with drives > 1TB
I had the most problems with WD Red.. just use Enterprise, you won't regret it.
You can buy just 6 discs to get over 16TB and expand it later
P3R
Post by P3R »
Metzlmane wrote:I don't also recommend RAID 6 with drives > 1TB
Why?
Are you not aware that RAID 6 offer better redundancy (so better security from disk failures) than RAID 10?
Only possible if using the SMB firmware (still only in beta testing so not recommended for production environments) and formatting the volume for the new storage pool feature.
fantomas
Experience counts
Contact:
Post by fantomas »
For 10 disks, 2x5-0drive raid5 or raid6 should be ideal. While you get 2 to 4 disks lower capacity, you'll have better reliability and better performance in case of failures
experience with administration of UN*X (mostly linux) and applications on internet servers since 1994...
markusha
Post by markusha »
Hello
Getting back to disk compatability
i own Qnap 1079 pro and i sold all HDD's and upgrading to new once
the question is
For the compatability list shows up to 12TB per HDD
and item description shows
supports up to 10 hdd's 3TB per HDD each
so does it support 6-10-12TB or only 3TB max per HDD
dolbyman
Post by dolbyman »
please don't dig up 8 year old topics...open a new one
marked for closure
Locked
