TS-469L Memory Upgrade
jerrygaoyi
Postby jerrygaoyi » Thu Jul 10, 2014 11:09 am
I just upgrade my new TS-469L by Crucial CT25664BF1339 2GB memory, but after I installed this memory to the empty slot, the qfinder cannot find this nas anymore. But when I uninstall the memory, qfinder can find my nas again. Do I get a bad memory? I saw many people said Crucial CT25664BF1339 works with TS-469L. Any solution for this?
Palmarenko
First post
Re: TS-469L Memory Upgrade
Postby Palmarenko » Sun Jul 13, 2014 1:31 am
I know from experience that the same part numbers are used for different memory modules. The one you need has to have 8 memory chips. Most newer ones seem to have 16 chips (8 on both sides) and that won't work.
schumaku
Contact:
Postby schumaku » Tue Jul 15, 2014 4:24 am
Only single-side and single-channel - others don't work.
Idlewizard wrote:They just didn't design the BIOS to correctly initialize anything configured differently than the modules they were shipping
No, the Atom has limitations shown above, nothing the BIOS can do.
eduardoo
Postby eduardoo » Thu Jul 17, 2014 11:30 am
I also got a 469L recently and upgraded ram as well. My experience is also that 8-chip variety works. The 16 chip Kingston that had around didn't work. I looked around in used shops and got myself a Micron one (Sorry, forgot to copy the part number) that has 4 chips per side and that worked. I was looking for those "known to work" ones originally but 2GB So-dimm DDR3 rams are not exactly current market material and they were almost impossible to find, and searching the net seems to indicate that 8-chip is the holy grail. BTW, the sign of it working (as I noticed) is that upon plugging in power, the fan speed is lower (than with the non-working ones), and you get the start-up beep pretty soon.
Sorry for being not much help, but looking for a piece of RAM that works on the cheap was kinda difficult, and I was quite happy to have got it working.
naucha
First post
Postby naucha » Sun Mar 22, 2015 5:47 am
Just to add to this thread. Corsair CMSO2GX3M1A1333C9 worked for me.
physh
Postby physh » Sat Apr 02, 2016 5:34 am
Bought kingston valueram KVR13L9S6/2 (4 chips) for 12$.
Didn't work in the expansion slot - for some reason the system recognized it as e-sata and hung up.
So i tried to switch it with the primary memory stick (Qnap glues on A-Data...) and it worked.
schumaku
Contact:
Postby schumaku » Sat Apr 02, 2016 2:16 pm
physh wrote:Bought kingston valueram KVR13L9S6/2 (4 chips) for 12$.
Odd, can't find any formal specs by Kingston for this model ... suspect brand pirate packaging.
physh
Postby physh » Mon Apr 04, 2016 2:06 am
Sorry, missed an "S" in its #.
khunpoom
Postby khunpoom » Sun Oct 15, 2017 6:51 am
For my Qnap TS-469L with CPU D2701 working in main internal slot (not the empty slot) - single HYNIX 4GB HMT351S6BFR8C (8 chips at every side, total 16 chips) also i test single Elpida 4GB EBJ41UF8BCS0-DJ-F (8 chips at every side, total 16 chips) its working
ETH 0xd8F2b22e50B200214303E4f0B95435c918ca9CcF
khunpoom
Postby khunpoom » Mon Oct 16, 2017 12:01 am
also working with 2gb AMD R532G1601S1S-UO (4 chips at every side, total 8 chips)
Who is online
Users browsing this forum: No registered users and 6 guests
