I got an UX-800 and is being added to my TS-853Pro.
Now moving files from a RAID-5 on the TS-853 to a single hard disk on the UX for backup and reformatting the RAID.
Reseller told me that speed using disks on UX or TS will be minimun and "you will not notice that difference at least your network is very optimized (!!).
Using a SSD as read cache on TS-853 Pro.
Well moving files from RAID on TS to UX is about 16 Gytes in 10 hours....
(PD: Regarding this seems file station hungs with a long name file and stopped moving files.)
Latest numbers are 160 Gbytes in 8 hours.
Anyway moving files from the RAID to an USB3 SSD on fron USB port is slow.
Never on the last year I got a decent file tranfer speed on any situation.
It is normal or just the hardware is crappy????
Transfer speed
- Trexx
Re: Transfer speed
I would try using a back USB port and make sure it is a USB3 port. Even then you will get MAX 5Gb/S throughput from the USB port itself (probably less depending on your SSD). That will only be for large file writes and will be slower for alot of small files. You will probably also get higher throughput via BackupStation /HybridBackupSync.
Your UX chassis is going to have the same 5Gb/s throughput TOTAL for all disks on the chassis.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Re: Transfer speed
And if we look at real world implementations instead of theoretical hardware specifications it will probably at best be much closer to about half of that number due to the protocol overhead.Trexx wrote:Even then you will get MAX 5Gb/S throughput from the USB port itself...
Re: Transfer speed
Thanks to both!
Yes, we are moving many small files and seems performances are very far away from theoretical numbers...
