I have a TS-412 running the newest firmware. I have been using it for a few years.
I use the Multimedia builtin share to store things for my household. I just tried to map a drive and copy files to it and am getting an error message saying there isn't enough space. It says I need to add x amount of size in order to complete my copy. I look at the control panel for the NAS and see no setting for a folder limit. According to the CP, I have 325GB in that folder.
Is there a size limit or why else would this happen?
Shared Folder Size Limitation?
- OneCD
- Don
Re: Shared Folder Size Limitation?
Useless information. Always provide the version and build numbers. What is newest today might not be the newest tomorrow.djtech2k wrote:I have a TS-412 running the newest firmware.
Volume is full?Is there a size limit or why else would this happen?
- schumaku
Quotas in place?
- Trexx
NW recycle bin needing emptying?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
It turns out this must have been an authentication issue somehow.
I have my NAS domain integrated. I have the permissions setup on the NAS so that my domain users should have full control of a certain builtin share/directory. I have not been able to get it to work like that though. When I try to browse to that share, the logged in domain users do not have access. They sometimes can read, but they do not have complete write access.
In this case, I mapped the drive and I could see the data. It even let me start to copy data but it came back and said there wasn't enough space. Once I dropped the mapped drive, re-mapped using a local NAS account, then it worked fine.
So I still do not know why domain accounts do not have the full access I have set it to.
