I'm solving problem. When I'm in my local network I can mount SMB share without problem. On QNAP I have configured OpenVPN which works great. After connection I can connect to QNAP Desktop without problem. But mounting SMB share doesn't work. I use the same command but with changed IP address.
Can I ask you for help?
[SOLVED] Unable to mount SMB share through OpenVPN
- schumaku
Re: Unable to mount SMB share through OpenVPN
Is this related to the other post -> viewtopic.php?f=185&t=136313 ?
No that's not the same problem. I have permit SMB share for user (which works) and can mount SMB - as is described in viewtopic.php?f=185&t=136313. In this case I cannot mount SMB share through VPN but in my local network it works.
- schumaku
Permitting you are using the QTS hosted OpenVPN, have not destroyed the default OpenVPN pool address config to overlap with any NAS LAN subnetworks, not set-up any limitations potentially blocking the OpenVPN pool addresses in the Microsoft Network Hosts access on the shared folder in question, and using the correct OpenVPN pool address ending in .1?
@schumaku you're right. I had set Microsoft Network access where I had specified IP addresses. I didn't know that this rule can influence SMB share. MANY THANKS for helping!
