Hi, can I access files of an usb hd connected to router using filestation?
I want to copy files from usb hd to my nas.
Regards
Copy or read files from usb hd to nas
NAS Qnap TS-251, 8gb
Re: Copy or read files from usb hd to nas
hdd connected to the router..why?
how about connecting it to the nas ?
if the router has smb filesharing you can just mount the smb on the nas (most routers are terribly slow though)
Hdd connected to the router because before last week I didn't have a nas. I bought it for sharing files with my family and before last week i did it by my router netgear. It offered me a free ddns and ftp server by usb port. Now I want to set nas to use it for this reason.
Do you know if d6400 netgear has smb?thanks for your support.
family fileshare sounds like risksy business(see threads about hacked qnap units that are exposed to the web)
I looked at the manual quickly .. and yes..."readyshare" is using smb
I read manual but I don't see "remote connection" from filestation. Where is it?
I know risks but, if you can't or doesn't wanto share, why do you want to buy a nas?
- Don
Probably faster to connect usb drive to QNAP.
top right in file station has remote connections..hard to miss
