After a recent upgrade I like lots of others it seems lost guest access.
I logged a case but after waiting 1 week cant wait so came looking here, a big thanks to BrutisNZ fro his fix detailed at viewtopic.php?f=185&t=149124&start=30#p719235
Being used to working on linux it didnt worry me applying the changes to get me up and going whilst I await an official fix
Guest access broken on TS-421 4.3.3.0967 but fixed thanks to BrutisNZ
- Don
Re: Guest access broken on TS-421 4.3.3.0967 but fixed thanks to BrutisNZ
This was fixed in the latest beta release.
It may have been fixed for many but i am still unable to access my NAS from my windows explore even after the update.
What looks like worked for me is i added a user to my NAS with the same user name and password of my windows log in and it is now working.
