renamed folders showing same files as new folder
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
project3it-wj
First post
Post by project3it-wj »
Model: QNAP TS-431XU-RP
Firmware: Beta 4.4.1.0998 (Public Beta 3) build 20190715
Issue:
SMB guest access issue occurred. Upgraded to Beta firmware, but didnt resolve issue.
Created a new test folder and guest access worked.
Renamed the folder I couldn't access and create a new folder with the same name as original folder.
Went into new folder and all the files from the original folder were in there. Looked in original (renamed) folder and all the files were in there.
Create a new test file in one of the folders. File shows in both the original renamed and new folders.
Checked space - space isnt doubled up.
Cant understand why I now have two folders that have exactly the same files in them. Any ideas what is causing this?
Return to “File Sharing”
