QSync deleted all my Sync Folder and Files on Both of PC and NAS
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
sairy
Post by sairy » Fri Aug 28, 2020 1:40 am
Hi
I really need your helps. I just re-initialize my T-251+ and update to newest QTS 4.4.3.1400 firmware. I setup my QSync at normally and they began to sync all Folders and Files on my PC Windows 10 to NAS. The problem is QSync deleted all the files and Folder of my Project and some Pictures JPG PNG files on some others folders. I remembered that I set an option to sync Pictures Folders with PNG and JPEG only (the RAW files and Photoshop files will not sync to NAS and keep it local in my PC), and now all JPEG and PNG files on my NAS and PC gone, only the RAW files and Photoshop files keep in my locals PC and NAS. Also others files and sub-folders in my WAMP Project Folder were deleted. I cannot find the restore in my PC Recycle Bin and I only Recovery some files in WAMP folder (which store in a SSD). I tried to find the deleted files and folders on the Network Recycle Bin but they are empty, the logs file on QSync Central does not show deleted files and folders, but the logs of File Update Center on my PC Qsync Client shown they were deleted, I tried to click to restore button but the files and folders does not exist. So please view my screenshoots for more details and if someone has this problems too and you have solutions please help me. The project WEB folder WAMP is very important, I built my website a year and nearly done but now It gone and I cant recovery them with software any more. Thank you so much for your helps.
Regards
nonotrb
First post
Re: QSync deleted all my Sync Folder and Files on Both of PC and NAS
Post by nonotrb » Tue Apr 06, 2021 12:08 am
Hi sairy,
Did you find a way to recover your files and sync again Qsync with your NAS?
It happened almost the same thing to me this week-end, Qsync icon on my Mac went on red, on the file station I have a message saying that "file/folder does not exist" and all my files are deleted.
Thanks for your feedback.
Nono
sairy
Post by sairy » Tue Apr 06, 2021 1:03 am
Hi Nono
I contacted with QNap Support and they give me links to help me recovery my files:
http://qnap support.net/teknik-destek/raid-0-5-6-ve-10dan-veri-kutarma/photorec-ile-veri-kurtarma/
(remove space between "qnap" and "support")
The files will be recovered in original if you are stop using the NAS, stop doing everything or you will lost more datas. Photorec can’t help you recovery files names and folder structures. I recommend you use TestDisk first because it’s will recovery all files and folders if it can. Also, very important thing that you need create a backup Disk Image to store all scratches core datas and you can use test disk or others Recovery program to try recovery datas frim this Disk Image. Also please follow carefully the instructions of the tutorial, stop using both PC and NAS disk which have data lost and stored before, and when you recovery, I recommend you use external HDD or other disk to store new data in case you could not recovery datas all and lose some important datas. Last things if you got hard to use code, you can try Recuva professional Recovery for more easier than the Photorec, it’s can recovery datas which folders structures and a lot of files types support, especially video and images, it also have Disk Image creator to save scratches and core data from disk which lost datas. Hope it help. Also I can’t recovery my website databases because Photorec and Testdisk do not support new file types of MySQL.
Regards
Sairy
dolbyman
Post by dolbyman » Tue Apr 06, 2021 1:06 am
doubt qnap gave you the link to that website..as the forum autocripples the website (qnap intruduced this "revenge" measure years ago)
sairy
Post by sairy » Tue Apr 06, 2021 1:15 am
Hi
I have no need to write a long post for the guy who in exactly my hard situation like me before. I also attached screenshots
of the reply from Qnap service here if you feel weird.
dolbyman
Post by dolbyman » Tue Apr 06, 2021 1:20 am
well check the link that you posted further up..compare it to what they gave you
so qnap is giving out links to 3rd party websites that their own forum cripples deliberately
this is beyond retarded then
p.s.
sorry that I doubted your post then ..but you can see how insane this is ?
sairy
Post by sairy » Tue Apr 06, 2021 1:33 am
p.s.
I copy the link in email and paste to the Editor, but when I submitted the post, the link got change. You can see my screenshot. I have no idea how to post the orginal link to this topic, you need to type it manually.
dolbyman
Post by dolbyman » Tue Apr 06, 2021 2:08 am
as I said twice before ..the forum automatically cripples links to this website...this is not your fault ..this is what qnap did
worst part is that someone bought this(crippled) domain a while ago and was serving malware from this ..infecting qnap forum members clicking on these crippled links
OneCD
Ask me anything
Post by OneCD » Sat Apr 10, 2021 4:48 am
I've done what I can with those links. Just need to copypaste the URL then remove the whitespace between "qnap" and "support".
Return to “File Sharing”
