i'm having some unusual behaviour with Qsync and wondering if there is a way to be able to 'reset' the qsync database and force the qysnc application to re-create all indexes again? I have a number of users connected to the QNAP via qsync so it's important that nothing major changes. I remember reading about this in the past (that you can refresh/reset the database so that all indexes are established again).
any assistance in this matter would be great.
Qsync Database - Refresh
- spile
- Been there, done that
Re: Qsync Database - Refresh
Simply uninstalling the application from clients and stopping on your NAS?
Simpler to delete and recreate the folder pairs though.
With a mirror sync set up you should not be at risk from loosing your data.
