Problem trying to connect my ubuntu-server using my Go-->connect to server option an I get this error msg.
There was a problem connecting to the server xxx.xxx.x.xx
The server may not exist or it is unavailable at this time.
Check the server name or IP address, check your network connection, and then try again.
I know can access the files using using ssh but I would like to know how to connect with smb using my MacBook. I am using ubuntu server 18.04.5. What am I doing wrong?
Problem trying to connect my ubuntu-server using smb
- steve102
Nas1: TS-453D -Firmware: 4.5.3 Build 1652
Nas2: TS-453D -Firmware: 4.5.3 Build 1652
Nas3: TS-253 Pro-Firmware: 4.5.3 Build 1652
Nas4: TS-451+ -Firmware: 4.5.3 Build 1652
Windows 7 | Apple| Linux | Apache | Perl
Re: Problem trying to connect my ubuntu-server using smb
Did you try in Go > Connect to Server:
It should ask for the password, then the shares that you want to mount (Public, samba_user etc).
You can user Wireshark https://www.wireshark.org/ to analyze the smb2 protocol negotiation.
smb://samba_user@qnap_server/
