Share files to local network
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
Poldom
Post by Poldom » Wed Apr 07, 2021 2:21 am
Hi
I want to share some files of the Nas to the local network, making impossible to access to them from the Wan.
Is it possible?
dolbyman
Re: Share files to local network
Post by dolbyman » Wed Apr 07, 2021 2:38 am
Sharing files in the LAN is the default usage of a NAS, unclear what you mean .. can you elaborate ?
Poldom
Post by Poldom » Wed Apr 07, 2021 12:45 pm
Hi @dolbyman, it's true, thanks for your contribution.
I'm using my Qnap to share files in my Lan, as usual. But some of these files are shared in the Wan, too, to certain users.
Now I need an "only local user". I need a new user that cannot be usable over the Wan. I cannot do this using my firewall, as I used to. But I don't know if it is possible to do this using the qnap OS.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Wed Apr 07, 2021 1:46 pm
afaik on the qnap, you can set what user has access to which shares. also what permission like read/write.
but for wan... isn't that usually the firewall rules on your router?
so you don't want them to be able to remotely access the nas from the internet ya? then shouldn't you only provide the vpn login credentials to users that actually should have remote access? without that, the other users can't remote to your nas. vpn server ideally setup on the router. vpn client is then run from whatever pc is trying to access your nas from offsite over the internet.
https://www.youtube.com/watch?v=PgielyUFGeQ
anyway sounds to me like you are just simply exposing your nas online for remote, without using vpn for this. you shouldn't :'
https://www.reddit.com/r/qnap/comments/ ... _from_the/
if remote access is not even a requirement, you can simply leave router like pfsense on defaults which is already secure as it's not port forwarding or exposing your lan to the wan. problem solved 8)
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 +16gb ddr4 Crucial+ QWA-AC2600 wireless+QXP PCIE
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[Backup] QNAP TL-D400S 2x 4TB WD Red Nas (WD40EFRX) 2x 4TB Seagate Ironwolf, Raid5
[^] QNAP TS-659 Pro II
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Qotom Pfsense|100dl/50ul MBPS FTTH Internet | Win10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
dolbyman
Post by dolbyman » Wed Apr 07, 2021 7:45 pm
yes..never expose your nas to wan ..there is malware and ransomware attacks again right now ..so stop that right away
Return to “File Sharing”
