I can access the NAS fine from the Web GUI, and I can see in the system log that it updated OK. But for some reason after the update and restart it is rebuilding the array. I didn't have bitmap enabled, so it's taking awhile. It shows every drive as "Good" except drive 4 which is "Rebuilding."
I can access the NAS from a Mac using AFP, but SMB does not appear to be loading/loaded. Looking via SSH I gathered the following info:
[~] # ps -ef | grep mbd
3628 admin 448 S grep mbd
[~] # smb2status
smbd (samba daemon) Version 4.4.16
smbd (samba daemon) is not running.
max protocol SMB 3 enabled.
[~] # /etc/init.d/smb.sh restart
Restarting SMB services:
Shutting down SMB services: smbd smbd-notifyd cleanupdlstat failed on directory /usr/local/samba/var/cores: Input/output error
Failed to create /usr/local/samba/var/cores for user 0 with mode 0700
Unable to setup corepath for winbindd: Input/output error
nmbd.
Shutting down winbindd services: winbindd.
rm: can't stat '/share/CACHEDEV1_DATA/.samba/cache': Input/output error
chmod: /share/CACHEDEV1_DATA/.samba/lock/msg.lock: Input/output error
mkdir: can't create directory '/share/CACHEDEV1_DATA/.samba/': Input/output error
mount: tmpfs: can't read superblock
rm: can't stat '/usr/local/samba/var/locks': Input/output error
ln: /usr/local/samba/var/locks: Input/output error
locks path was set to /share/CACHEDEV1_DATA/.locks
Starting winbindd services:lstat failed on directory /usr/local/samba/var/cores: Input/output error
Starting SMB services:lstat failed on directory /usr/local/samba/var/cores: Input/output error
done.
[~] # ls -als /var/log/log*
12 -rw-r--r-- 1 admin administrators 8745 2021-04-22 13:59 /var/log/log.nmbd
12 -rw-r--r-- 1 admin administrators 10395 2021-04-22 13:32 /var/log/log.nmbd.old
0 -rw-r--r-- 1 admin administrators 0 2021-04-22 09:01 /var/log/log.smbd
[~] # testparm
Load smb config files from /etc/config/smb.conf
rlimit_max: increasing rlimit_max (4096) to minimum Windows limit (16384)
WARNING: The "null passwords" option is deprecated
WARNING: The "server schannel" option is deprecated
Processing section "[printers]"
Processing section "[Web]"
Processing section "[Public]"
Processing section "[homes]"
Processing section "[Trauma]"
Processing section "[Outside]"
Processing section "[home]"
Loaded services file OK.
ERROR: lock directory /share/CACHEDEV1_DATA/.samba/lock does not exist
ERROR: state directory /share/CACHEDEV1_DATA/.samba/state does not exist
ERROR: cache directory /share/CACHEDEV1_DATA/.samba/cache does not exist
Invalid combination of parameters for service Outside. Level II oplocks can only be set if oplocks are also set.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
server string =
workgroup = NAS
local master = No
preferred master = No
smb2 leases = Yes
max log size = 10
cache directory = /share/CACHEDEV1_DATA/.samba/cache
lock directory = /share/CACHEDEV1_DATA/.samba/lock
pid directory = /var/lock
state directory = /share/CACHEDEV1_DATA/.samba/state
printcap cache time = 0
printcap name = /etc/printcap
show add printer wizard = No
min receivefile size = 256
name resolve order = host bcast
unix extensions = No
conn log = Yes
enhance acl v1 = Yes
guest account = guest
map to guest = Bad User
null passwords = Yes
passdb backend = smbpasswd
security = USER
server signing = No
smb passwd file = /etc/config/smbpasswd
username map = /etc/config/smbusers
deadtime = 10
socket options = TCP_NODELAY SO_KEEPALIVE
template homedir = /share/homes/DOMAIN=%D/%U
winbind enum groups = Yes
winbind enum users = Yes
winbind expand groups = 1
winbind scan trusted domains = No
dns proxy = No
fruit:veto_appledouble = no
fruit:nfs_aces = no
streams_depot:check_valid = no
streams_depot:delete_lost = yes
idmap config * : backend = tdb
delete veto files = Yes
map archive = No
map readonly = no
store dos attributes = Yes
veto files = /.AppleDB/.AppleDouble/.AppleDesktop/:2eDS_Store/Network Trash Folder/Temporary Items/TheVolumeSettingsFolder/.@__thumb/.@__desc/:2e*/.@__qini/.Qsync/.@upload_cache/.qsync/.qsync_sn/.@qsys/.streams/.digest/
kernel share modes = No
posix locking = No
wide links = Yes
acl allow execute always = Yes
create mask = 0777
directory mask = 0777
force unknown acl user = Yes
invalid users = guest
use sendfile = Yes
vfs objects = catia fruit qnap_macea streams_depot
[printers]
path = /var/spool/smb
browseable = No
printable = Yes
use client driver = Yes
guest ok = Yes
[Web]
comment = System default share
path = /share/CACHEDEV1_DATA/Web
browseable = No
aio read size on sequential = 4097
recycle bin = Yes
guest ok = Yes
inherit permissions = Yes
smb encrypt = No
valid users = root
strict allocate = Yes
streams_depot:check_valid = yes
[Public]
path = /share/CACHEDEV1_DATA/Public
browseable = No
recycle bin = Yes
guest ok = Yes
read list = Test
smb encrypt = No
valid users = root Test
[homes]
path = /share/CACHEDEV1_DATA/homes
browseable = No
recycle bin = Yes
guest ok = Yes
smb encrypt = No
valid users = root
[Trauma]
path = /share/CACHEDEV1_DATA/Trauma
recycle bin = Yes
guest ok = Yes
smb encrypt = No
valid users = root admin Staff @administrators @everyone
write list = admin Staff @administrators @everyone
[Outside]
path = /share/CACHEDEV1_DATA/Outside
oplocks = No
guest ok = Yes
invalid users = Staff guest
smb encrypt = No
valid users = root admin Test @administrators @everyone
write list = admin Test @administrators @everyone
[home]
comment = Home
path = %H
root preexec = /sbin/create_home -u '%q'
read list = %u
read only = No
valid users = %u
write list = %u
Thanks in advance.
